Front spring-seat "cushion"
Old Nov 21, 2022 | 08:15 AM
Stamford's Avatar
Default Front spring-seat "cushion"
I'm replacing my front shocks and mounts. I have one shock/spring out and much of the rubber parts are shot and will be replaced. The one thing I can't seem to find is the "pad/packing/isolator??" that the spring sits on in its seat. It's round, made of white plastic and has locating tabs. I can't find a replacement and none of the parts diagrams show that part. Is it even necessary?
Old Nov 21, 2022 | 08:31 AM
Pistnbroke's Avatar
I did find one lowering conversion where the whole of the top mount is solid 1/2 in plate going straight between the sping and the body.
Old Nov 21, 2022 | 08:44 AM
Stamford's Avatar
The part I'm looking for is what the bottom of the spring rests on. It came out of my left shock and was in pieces when I separated the spring from the shock.
Old Nov 21, 2022 | 08:56 AM
Looking at SNG Barratt's - looks like it may have been redesigned - as I have the white plastic piece with the tab for the spring to sit against
https://www.sngbarratt.com/English/#...20Id%202962768)
Old Nov 21, 2022 | 10:56 AM
MickeyR's Avatar
If it's the one I'm thinking of, it's tapered so as to orient the spring at the correct angle. There's been a discussion here about its relevance, though...
Old Nov 21, 2022 | 12:15 PM
Pistnbroke's Avatar
If you look at a normal ford of the right era they don't have all this plastic cushioning ..I think its just done to avoid warranty issues in the rare occasion you get a metallic bang ..that's why I am just packing the top to adjust for worn springs etc keep it simple stupid and cheap .
Old Nov 21, 2022 | 01:18 PM
michaelh's Avatar
I believe that's the 'packer' that you may or may not have multiples of at the bottom of the spring.
The white piece with the tab is, I *think*, MJA2189AA, 'Packing and locator ' according to JTIS, but shows on Heritage as a 'Jaguar Nut' (??) and is unobtainium, unless it comes in the road spring kit. I can't find any pictures of it.
Stamford
Nov 24, 2022 01:08 AM
MrKitty
Jul 23, 2021 05:24 PM
dfbender
May 12, 2021 01:16 PM
RJag
Apr 8, 2014 01:38 PM
rasputin
Jul 20, 2013 05:12 AM
