Front Spring / Shock
Old Jul 13, 2014 | 02:18 PM
Jim D's Avatar
Default Front Spring / Shock
Hello - preparatory to replacing front shock absorbers and and shock mounts, it occurred to me that it might be possible to remove the spring/shock absorber as an assembly without removing the upper control arm / wishbone.
Is that reasonably possible?
Thanks!!!
Old Jul 13, 2014 | 03:33 PM
RaceDiagnostics's Avatar
Yes, I did it on my 2002 4.2 XK8. The top ball joint was split from the hub at the time.
Old Jul 13, 2014 | 05:33 PM
Jandreu's Avatar
You will have to either break the ball joint loose from the hub so the wishbone can drop down or remove the Fulcrum bolt and the top of the wishbone. One or the other.
bamforp
Aug 14, 2024 05:36 PM
Neil1664
Jan 20, 2022 08:59 PM
ym37tech
Feb 8, 2016 01:04 PM
EZDriver
Sep 8, 2015 09:25 AM
Tar
Sep 6, 2015 11:24 AM
