need some advise, my front suspension sound like "knirk", "knirk" on the left side, is it the upper spring mounting plates that are bad, the springs, or the shocks? - I suspect the plates, but I'm not 100% sure!
Your advise would be great and highly appriciated prior I order the part's - many thanks in advance
It looks from the picture that the upper shock mount could use replacement.
How is the front end ride height? - the other indication of worn upper shock mounts.
Thanks Ungu,
the foam is a bit crumpling, so yes I agree, I should replace them.
the front is quite low, have not measured it, but I have no other problems
with the suspension when driving, fast or slow, besides from the "knirk" sound
when driving slow over bumps.
spray'd both fronts springs, bushings, shock's - in other words everything until the can was empty - no more annoying "knirk" "knirk" sound from front suspension.
Pretty sure it will come back once whatever bush/joint causing it has dried out again:
but as long as it only costs a can of spray lube and definately isn't a progressive impending failure, guess its possibly a cheap fix as long as you can but the spray in bulk?
when it happens again spray bushes/joints/parts one at a time to help isolate what is causing it.
