Fuel cap/trunk switch removal
Old Sep 20, 2021 | 12:39 PM
jaryn's Avatar
Default Fuel cap/trunk switch removal
Hi guys, I would like to replace bulb in the above mentioned switch, however by taking a quick view, I did not find an easy way how to remove it. Maybe someone already did that and could save me some time. First idea is to remove fuse cover visible when drivers door is open. I was able to reach the switch from behind (however its not possible to see inside due to door), so maybe there are some clips? I am bit afraid of brittle plastic and dont want to crack it. Another idea is to remove the cover under the steering wheel (which I already did in the past when changing tilt motor) but I dont remember if from that side it will be accessible. Thanks in advance for any hints.
Old Oct 2, 2023 | 02:48 AM
Tim Goz's Avatar
I am looking to do the same on my 2000 xkr. cant find info on how its fixed or access
Old Oct 2, 2023 | 05:09 AM
jaryn's Avatar
Hi, it helped me to check the whole picture how the button looks like: https://www.autoreservejaguar.com/xk...se-switch.html
Then I was able to locate the two places where to press it (from inside). I think I removed the cover under the steering wheel or that little thing next to that swith.
Old Oct 2, 2023 | 05:22 AM
Tim Goz's Avatar
Thank you, a big help
TexMurphy
Aug 11, 2021 10:54 AM
Nanonevol
Mar 2, 2018 07:12 PM
Pristine97XK8Convertible
Mar 19, 2017 01:11 AM
Johnken
Sep 25, 2016 01:58 PM
patrick12
Jun 13, 2009 08:53 AM
