Fuel cleaners/additives
Old Feb 15, 2009 | 12:16 PM
SeismicGuy's Avatar
Default Fuel cleaners/additives
For the last several cars I have owned (all of which had fuel injection), I got in the habit of adding a can of fuel injector cleaner or fuel system cleaner or octane booster every now and again. Do any of you folks do this and is it okay or something that should be avoided with Jaguars?
Thanks,
Doug
Old Feb 15, 2009 | 12:59 PM
Gus's Avatar
Gus
I have been using BG 44K for years and it works.
Old Feb 15, 2009 | 03:23 PM
hlgeorge's Avatar
I ditto Gus. BG 44K is the best I have found and it has worked for me every time. It is expensive, but if you are vigilant, you can get a good price on ebay. I just bought 6 cans for $50.
Old Feb 15, 2009 | 06:35 PM
Montauke's Avatar
Would you use the BG Fuel Injection System Cleaner (part no. 210) in conjunction with the BG 44k (part no. 208)? Or is just using the BG 44k enough to clean out the fuel system?
Old Feb 15, 2009 | 07:40 PM
Goldlion's Avatar
Say Gus, the mileage on your vehicles is impressive. I would like my 2005 XKR to make it too 100,000 (+) miles. What do you recommend as the most key factors to reaching that goal.
Appreciate your thoughts on the subject.
Tim V.
Florida
Old Feb 15, 2009 | 08:28 PM
Gus's Avatar
Gus
Thank You! I change the oil every 3,000 mi, I fix what is broken, I add BG 44K about every 6mo, I check the obvious and drive the hxxx out of it. I run it hard and we take it everywhere. This car loves to be driven! The most important part of what I do is check many chat rooms to see the problems other people have and use what I learn and be proactive. My being proactive came from working on aircraft, no room for error. I have never replaced the trans fluid but plan to do so this spring. The expression “If it aint broke don’t fix” it is true. However, examine it and make sure.
Old Feb 15, 2009 | 08:59 PM
Goldlion's Avatar
Thanks Gus, sage advice! I'm there on proactive maintenance also and keeping the engine bay clean as well. I will give the BG44K a try. You are right about the driving experience. These XKs are all about cruising down the road...rain or shine. Enjoy the road ahead.
Regards
Tim V.
Old Feb 16, 2009 | 12:10 AM
hlgeorge's Avatar
I just use the BG 44K. It keeps my Rolls clean too!!
Old Feb 16, 2009 | 10:15 AM
SeismicGuy's Avatar
Thanks for the info. I was not familiar with the BG 44K stuff but will look for it in my local Pep Boys or AutoZone.
Doug
Old Feb 16, 2009 | 05:33 PM
hlgeorge's Avatar
Search for it on ebay.
Old Feb 16, 2009 | 06:03 PM
Gus's Avatar
Gus
You can get it at most dealerships or high end repair shops. E-bay is an option as well as www.motorcarsltd.com
Ragn0r
Sep 29, 2015 10:38 AM
moff1959
Sep 26, 2015 05:35 PM
XKE73EIconverter
Sep 26, 2015 10:21 AM
reb1999
Sep 26, 2015 08:41 AM
reb1999
Sep 25, 2015 10:00 AM
