Fuel Pump OEM vs. Aftermarket?
Old Aug 30, 2021 | 05:58 PM
FordPAGFanBoy's Avatar
Default Fuel Pump OEM vs. Aftermarket?
Hi All,
My 2001 XKR stopped running on me a few days ago and the fuel pumps went bad (again!!). I had them replaced in 2015.
Is the large price jump going to OEM worth the added cost? If the OEM pumps are worth 3x the cost I am willing do take the leap if it means getting a few more years before this dreaded job needs to be done again.
Thanks.
Old Aug 30, 2021 | 06:35 PM
xalty's Avatar
no
https://www.ebay.com/itm/NEW-ELECTRIC-FUEL-PUMP-FITS-FORD-LINCOLN-JAGUAR-MAZDA-MERCURY-REF-E2226-380700-/353509971597?mkcid=16&mkevt=1&_trksid=p2349624.m46 890.l6249&mkrid=711-127632-2357-0
Old Aug 31, 2021 | 11:18 AM
Markel's Avatar
No
Old Sep 1, 2021 | 02:02 PM
stu46h's Avatar
When I replaced my fuel pump several years ago, I bought the new one at NAPA because I wanted better quality than Autozone, etc. Fit was great and I'm glad I went this route. Price was higher, probably about $100.
Old Sep 2, 2021 | 02:30 PM
Red's Avatar
Red
I used Denso 951-0008, which I suspect was the original manufacturer at least for the earlier style pumps. Be sure the fuel filter has been changed too.
Old Sep 2, 2021 | 02:31 PM
xalty's Avatar
Originally Posted by Red
I used Denso 951-0008, which I suspect was the original manufacturer at least for the earlier style pumps. Be sure fuel filter has been changed too.
no it was ford/visteon and doesn’t need splicing to work
Old Sep 3, 2021 | 03:03 PM
CA Jag's Avatar
How much work is it to change the filter? Something you do only when changing the pump?
Old Sep 3, 2021 | 03:37 PM
Red's Avatar
Red
Fairly easy. Be sure to have new filter & new o-rings. Located near left rear wheel well. The bracket rusts easily so maybe plan to wire brush & repaint it black it yourself while the bracket is off. I think the Jaguar interval is longer, but I’d probably change whenever changing fuel pumps and every 30k-50k miles depending on gas quality and how long the gas sits around in the tank un-used. Usually forgotten, tho easy.
Here’s a good video
https://m.youtube.com/watch?v=Cwf9sz73fFs&noapp=1
Old Sep 3, 2021 | 11:24 PM
Kuddlesworth's Avatar
Anyone know of a cheaper fuel pump for the 4.2 cars. Jaguar want £400 or so. I know there is a pump you can sort of cludge together call Osias E2226 but I was wandering if there is a drop in replacement.
Old Sep 4, 2021 | 06:12 AM
Jon89's Avatar
To my knowledge no one here has found a viable aftermarket fuel pump for the 4.2 cars. A couple of members indicated that they planned to attempt to repair their 4.2 fuel pumps but thus far I have not seen a successful report of anyone doing so....
Old Sep 4, 2021 | 06:43 AM
I hope someone manufacturers a replacement at some point because if mine conks out I don't feel like spending £400+labour on a new fuel pump only for it to also die later on.
Old Sep 4, 2021 | 07:29 AM
Jon89's Avatar
The best way to keep your fuel pump from dying is to drive the car on a regular basis. Do not allow it to sit for weeks or months at a time....
Old Sep 4, 2021 | 07:52 AM
It's my daily car so it gets a lot of driving out of it. I also take it on holidays whenever I can. I think I do about 6k miles in it a year or there abouts.
convincor
Sep 3, 2021 05:34 PM
Mad_Russian
XJ40 ( XJ81 )
Apr 27, 2016 10:33 AM
Curt Lee
May 16, 2015 09:05 PM
mustangtyson
Feb 15, 2015 06:00 PM
MLRocafella85
Jun 29, 2011 05:55 PM
