Fuel Tank Quick Release
Old Dec 21, 2013 | 11:33 AM
Philagot's Avatar
Unhappy Fuel Tank Quick Release
It appears that my fuel pump has failed. I have the replacement and got as far as removing everything in the trunk to gain access.
The issue is the two quick release above the differential, there is no way to get to it!
I want to throw in the towel and have a mechanic do this work, maybe with a lift it can be done.
Does anyone know a good mechanic in the Philadelphia area?
Old Dec 21, 2013 | 01:52 PM
oyster's Avatar
Hi.
Take a look here:
http://www.jagrepair.com/images/Auto...eplacement.pdf
Old Dec 21, 2013 | 02:40 PM
smithtrevor's Avatar
Phil, to help an owner out on the UK forum who has a misfire problem, when your pump failed did it just 100% give up or was there any "symptoms" beforehand ?
Thanks..TS
Old Dec 21, 2013 | 02:49 PM
Philagot's Avatar
It Just stopped working. Drove home one day wouldn't start the next.
I appreciate the directions, I was using them earlier today, however without a lift i cant reach the quick release, either my hands are to big or the spot is to small
Old Dec 21, 2013 | 03:08 PM
oyster's Avatar
Have you seen this video?
Old Dec 21, 2013 | 05:02 PM
Philagot's Avatar
Doesn't help, I can't get to the fitting
Old Dec 21, 2013 | 05:09 PM
Gus's Avatar
Gus
Can you get the car high enough to put ramps under the rear tires?
Old Dec 21, 2013 | 07:19 PM
Philagot's Avatar
I lifted it and put jack stands under the frame, my hands don't fit with the removal tool.
Also a little uncomfortable making the adapter out of PVC.
When you remove the line does it seal or will the remaining fuel spill?
Old Dec 21, 2013 | 07:28 PM
WhiteXKR's Avatar
A couple of oz. of fuel that is in the lines will spill. The fuel is pumped from the bottom of the tank to the upper part where the lines are, so the fuel in the tank will not run out when the lines are removed.
Old Dec 21, 2013 | 08:07 PM
Gus's Avatar
Gus
Place your fuel line disconnect on your fuel line and use a stick or pipe to push it upward into the tank and pull down on the line at the same time.
Old Dec 22, 2013 | 01:04 PM
Philagot's Avatar
I'll try it again, at the next warm day.
My thanks for everyone's comments and help.
Old Dec 28, 2013 | 04:24 PM
Philagot's Avatar
After spending another 3 hours trying to get to the fuel lines under the car I officially give up. Does anyone know a good Jag Tech west of Philadelphia?
Old Dec 28, 2013 | 05:07 PM
EZDriver's Avatar
I know how frustrated you must be. It is certainly a terrible arrangement from a maintenance stand point. But, I was just thinking. What if you cut the fuel lines (some will crindge at this) at some point where you can put a coupling in the lines after reinstall. And remove the tank and fuel lines along with it. I'm not in your situation so this is just a wild idea. Feel free to disreguarde.
Old Dec 28, 2013 | 06:26 PM
test point's Avatar
I have never had the fuel pump failure either but have often wondered why not disconnect the flex lines at the other ends and remove them with the tank. There is probably a very good reason why that is not possible but inquiring minds would like to know . . . for sure.
Old Dec 28, 2013 | 06:54 PM
Gus's Avatar
Gus
Not sure what tool you are using but the one from Sears is the one I have and use and it seems it has a deeper reach than several others I have purchased and used in the past.
Link Sears.com
Old Dec 29, 2013 | 01:40 PM
EZDriver's Avatar
Test Point you have a great idea. Why not disconnect the fuel lines up stream get some slack in the lines and then pull the tank aft enough to get to the tank fittings from the boot area?
Old Dec 29, 2013 | 03:51 PM
RJ237's Avatar
If I ever have to replace the pump on either car I'll try that first.
Old Dec 29, 2013 | 04:52 PM
Gus's Avatar
Gus
If I were to do this I would install a brass coupling to eliminate any possibility of leaks.
Old Dec 30, 2013 | 08:13 AM
mike66's Avatar
Would that be a compression fitting, or would it require a flare tool? That would be safer and more secure than fuel line hose and clamps.
Old Dec 30, 2013 | 08:28 AM
Gus's Avatar
Gus
A flare tool.
