Fuel Trim Reports constant 0
Old May 12, 2015 | 11:44 PM
aslovik's Avatar
Default Fuel Trim Reports constant 0
I have a '00 XKR and am getting codes 171 and 174 meaning the engine is running lean.
I have an OBD2 scanner and installed Torque on my Android phone so I can do the "spray method" of finding where the air leak might be.
However, the Fuel Trim sensor readings on Torque are a constant 0. The O2 sensor display, however, registers values.
I've seen at least one video where people show the STFT display and how it changes if something is sprayed near the leak. What am I missing?
I visually inspected the intake valve, breather hose and they seem in really good shape. The part-load valve is also clear. Any suggestions?
The dealer said I should replace the valves, seal and hose, but they look fine. Should I just do it anyway?
Old May 13, 2015 | 06:51 AM
jamdmyers's Avatar
You might consider doing a smoke test, search the forum there are a number of threads on doing so and how to create you own 'smoke gun'. This should help narrow it down.
Old May 13, 2015 | 07:01 AM
WhiteXKR's Avatar
Perhaps try another scanner...this does not sounds right. Are long term trims also zero?
Old May 13, 2015 | 07:20 AM
JagV8's Avatar
Maybe it's so bad it's running open loop? (Check status.)
Old May 13, 2015 | 08:48 AM
RJ237's Avatar
Do not replace parts just because the dealer says to. That is the way they do repairs, throwing parts at the car until the problem goes away. Not cost effective.
Old May 13, 2015 | 08:11 PM
aslovik's Avatar
That's just it - I don't get long term fuel trim as even an option in Torque. Maybe it is because I am using the free version? Maybe I need a bedder scanner.
Old May 13, 2015 | 08:12 PM
aslovik's Avatar
No, it is running in closed loop (using O2 sensors). Thanks for the suggestion though.
Old May 13, 2015 | 08:13 PM
aslovik's Avatar
I agree, but seem to have little choice. I ordered the parts ($100) and will replace them even though they look good. If it doesn't work, on to a smoke test or something else.
Old May 14, 2015 | 09:47 AM
JagV8's Avatar
What does freeze frame data show? Won't be ltft zero! If it is, use another OBD tool.
RoyLittle0
Sep 17, 2015 01:05 PM
Bob Gelston
Sep 14, 2015 11:08 PM
OkieTim
Sep 8, 2015 04:48 PM
OkieTim
Sep 2, 2015 12:48 PM
