Full load breather hose
Old Mar 28, 2020 | 07:22 AM
MattArnold's Avatar
Default Full load breather hose
Hi there.
does anyone know if the O rings are available separately or is it a new hose?
or can I just buy a set of o rings and hope one fits? If so any recommendations for a set?
thanks
Old Mar 28, 2020 | 09:05 AM
RJ237's Avatar
Last month DavidYau reported that a shop that maintains classics recommended the use of HNBR o-rings. You can buy assortments from many sources.
Old Mar 28, 2020 | 09:52 AM
MattArnold's Avatar
forgive my ignorance, but what is HNBR?
thanks
Old Mar 28, 2020 | 12:35 PM
DavidYau's Avatar
HBNR is hydrogenated nitrile rubber. These O rings are used in the HVAC industry (Heating Ventilation Air Conditioning). Material technology moves with the times.
Not a lot of history of usage of HBNR in the automobile trade, but these are typically 2x the cost of rubber .... so read in that what you will.
O rings are cheap, and the full load breather is easily accessible, so I really don’t think it particularly matters in your case. If it leaks, just replace it - 2 minute job. I would recommend you don’t use one from a domestic supplier ie from a Walmart, Costco set. These won’t stand the temperatures in the engine bay.
Glenn Barickman
May 6, 2015 05:34 PM
34by151
Mar 13, 2015 10:27 PM
Dan R
Nov 15, 2014 11:56 PM
mvanoekel
E type ( XK-E )
Feb 26, 2013 04:32 AM
Gunz80
Feb 12, 2009 11:47 AM
