funny noise when getting in back seat
Old Feb 27, 2013 | 06:46 AM
sailorbill's Avatar
Default funny noise when getting in back seat
just got my 2005 xk8 and truns out that the grand kids can actually sit in the back seat!!!
anyhow, when I raised the lever to put the front seat forward, it makes a whirring sound, like a motor- but nothing seems to be happening.
any idea what is supposed to be happening. I would guess that the seat is supposed to move forward but may be broken (seat does work when sitting in it)
Old Feb 27, 2013 | 07:08 AM
Originally Posted by sailorbill
.......... anyhow, when I raised the lever to put the front seat forward, it makes a whirring sound, like a motor- but nothing seems to be happening.
Which lever are you raising?
The front button on the switchpack is moved in the direction shown in 'A' to move the seat backwards and forwards.
The only lever on the seat is the tilt lever to release the seat back so it can be tilted forwards. If there's a whirring noise and the headrest doesn't retract when you operate this lever, check the XK8/XKR FAQ's for the fix.
Old Feb 27, 2013 | 01:12 PM
Jag#4's Avatar
+1 on Graham's suggestion for the headrest motor. Mine doesn't work either, but I'm short enough the bottom setting works just fine.
When you tilt the seat forward, it tries to lower the headrest so it will clear the windshield header. Tilt it back in place and it wants to raise the headrest back up.
My fix? If you move the headrest selector switch to the lowest setting (all the way down if it was working), then when you tilt the seat forward for getting in the back, no noise. This is because it thinks the headrest is already fully retracted and the motor doesn't run.
If you wish to have the headrest go up and down, then see the DIY stickies as suggested to fix the internal cable. Rev. Sam even has a video how-to posted for the repair.
Old Feb 27, 2013 | 05:17 PM
sailorbill's Avatar
thanks guys
this forum is really helpful
Old Feb 27, 2013 | 06:06 PM
ccfulton's Avatar
The headrest fix is linked in the DIY sticky. Not too hard to do if you wanted to make it properly functional.
Old Feb 27, 2013 | 06:46 PM
gwagner's Avatar
Yep, that's it mine does the same thing. I'll get to it one of these days
When I read the thread title "funny noise when getting in back seat" all I could think of is a grunting noise trying to get in there
Jeh
XJ40 ( XJ81 )
Oct 13, 2015 09:23 PM
Dallas XK8
Sep 3, 2015 12:17 PM
dcvickers
Sep 2, 2015 06:14 PM
innzane
Sep 2, 2015 10:08 AM
