fuse locations/size
Old Jan 20, 2015 | 05:01 PM
Sabrina's Avatar
Default fuse locations/size
Hey guys,
I can't find my 1999 XK8 convertible's service pdf... can someone tell me:
1. Where the fuse is located for the back-lighting of the three center gauges?
2. Where the fuse/circuit breaker is located for the auxiliary heater pump?
3. Whether or not I need to do some sort of 'reset' to get the heater pump working again?
Just when I was bragging to Dennis that all was well... I loose heat and back lighting.
All the instrumentation works as well as the backlighting for everything but the oil pressure, voltage, time.
The heater vent controls work, I can send the air to the floor, the a/c ducts or the defroster. At highway speeds the heat is strong, but as soon as you hit the off ramp, the temperature drops. The engine is running normal, the temperature rises normally and stays within a normal range.
Please and thank you,
Sabrina
Old Jan 20, 2015 | 05:25 PM
SteveJacks's Avatar
Under the hood, fuse box on driver side, number 10, is what WhiteXKR said in another post, which runs the heater aux pump. I seem to recall it also powered some other non-essentials, not sure though. Maybe it is also why your lights are not working.
Ooh, just realized you wrote Cambridge, which I am guessing is the UK, bot Boston. Soooo, is the fuse box under "bonnet" on driver side still? I think it is.
Old Jan 20, 2015 | 05:45 PM
Sabrina's Avatar
on mine, #10 left hand side under the hood is a blank
Old Jan 20, 2015 | 05:48 PM
SteveJacks's Avatar
Well, I stepped in this time where I should not have. Someone will be along shortly I am sure, that will know more than me. Good luck.
Old Jan 20, 2015 | 07:40 PM
Sabrina's Avatar
no problem steve...
every fuse has been pulled and checked except the ones with the bands across them, a master re-set via disconnection of the battery did not help...
Old Jan 20, 2015 | 07:48 PM
Dennis07's Avatar
This should help you sort it out. I sure hope you've got some place with heat to do it.
File Type: pdf
Old Jan 20, 2015 | 08:21 PM
test point's Avatar
Default 2002 Jaguar XK8 fuse chart
Here is my cut-n-paste fuse chart in an easier format to see the assignments. While specifically for my 2002 Model Year there are few differences from '96 to '02 models.
File Type: pdf
Old Jan 20, 2015 | 08:31 PM
Sabrina's Avatar
hey Dennis...
per your drawings, the fuse is #15 and the relay is Relay #1 for the heater valve and auxillary pump.
Thank you so much!
I swapped the 10A #15 fuse with another, I rotated all 7 40A relays from one slot to the next (since their slots are not numbered like the fuses are)
HEAT, HOT, not luke warm, even at idle--thank you.
Still looking over the diagram for the backlighting on the 3 center gauges...
Test Point, thank you, does the 2002 have the same oil press/clock/voltage cluster as my 99?
I just noticed that Dennis' chart shows #15 engine fuse box as the fuse for the heater pump whereas the 2002 diagram uses that fuse position for the AC pump, so your caveat is well taken.
Old Jan 21, 2015 | 05:16 AM
SteveJacks's Avatar
Ok, I am jumping in again. For your center gauge cluster bulbs, have you actually checked the bulbs? Perhaps they blew due to a voltage spike of some sort. I know that seems like a stretch, but apparently something caused the aux pump fuse to blow, so maybe something zapped these bulbs, or a couple of them and perhaps one was already blown. And I wouldn't suggest checking the bulbs as a first step if not fairly easy to check. The veneer dash panel is easy to remove by pulling it toward you, no real magic. Then 4 philips screws holding the gauge cluster in place, one electrical connector, which may not need to be disconnected. The bulbs are accessible from the back side. Easy to remove, visually inspect, and or use an ohm meter to check if open.
Old Jan 21, 2015 | 05:40 AM
WhiteXKR's Avatar
+1, I agree with Steve. The 3-gauge cluster lighting is not on it's own fuse. It is also not unheard of for both of those bulb to go out at the same time.
Old Jan 21, 2015 | 06:00 AM
Sabrina's Avatar
Thank you Steve and WhiteXKR!
Does anyone know the US bulb type/number for backlighting the 1999 XK8 convertible 3 gauge cluster (Oil/Clock/Volts)?
Old Jan 21, 2015 | 11:59 AM
SteveJacks's Avatar
BP161
https://www.jaguarforums.com/forum/x...-please-59857/
Old Jan 24, 2015 | 11:48 PM
Sabrina's Avatar
Thank you Steve,
Both bulbs burned out at the same time.
New ones are the same brightness as the driver's gauge stack.
:O)
aode06
Jul 28, 2023 02:26 PM
hoodun
Nov 20, 2022 02:35 PM
goingjag
Sep 30, 2015 09:27 PM
ziondio
Sep 29, 2015 01:58 PM
