Fuse Problem XKR
Old Jun 16, 2017 | 04:20 PM
kenatofc's Avatar
Default Fuse Problem XKR
These are 3 fuse boxes. driver's side passenger side, trunk.
None of the diagrams I have for my 2002 XKR match and I am trying to figure out what fuse goes where ??
1 and 3 are the passenger side, 2 is driver's side and 4 is trunk. Current problem is that side mirrors inop as are passenger side windows ?? Probably more till I sort them out !!!
Thanks,
Ken in WV
Old Jun 16, 2017 | 05:17 PM
michaelh's Avatar
Ken,
Try this one. I can't get a match on the LHS of that fusebox either; they seem to have got the guide out of order. The door control module is the only 25A fuse in there. Should be F15, but sat in position 11.
Old Jun 16, 2017 | 05:58 PM
Gus's Avatar
Gus
This link should help http://jagrepair.com/images/Electric...eLocations.pdf
Old Jun 17, 2017 | 01:21 PM
kenatofc's Avatar
Gus,
Thanks for the download. The fuse charts in the book do not match the number of fuse openings I have in mine. See photos verse diagrams. Also, what is the number 1 position on each fuse location ?? Appreciating your help. I am going to look up the info for an 01 since my build date was September ??
Ken
Old Jun 17, 2017 | 08:43 PM
Gus's Avatar
Gus
Use a flashlight on the fuse box and look to the side of the fuse and you will see the number embossed for the position.
Gus
www.jagrepair.com
Old Jun 18, 2017 | 08:50 PM
kenatofc's Avatar
Gus,
Had to also use a magnifying glass to find the tiny numbers. Never knew... Thanks for the tip. Still unable to adjust side mirrors... Cannot seem to locate that fuse or control relay ?
Ken
Old Jun 19, 2017 | 04:00 PM
Gus's Avatar
Gus
See if you can follow the wiring diagram to find the feed.
Link http://jagrepair.com/images/AutoRepa.../jagxk2002.pdf
Old Jun 29, 2017 | 10:51 AM
kenatofc's Avatar
There is nothing specific about the fuses except for something about each of the door fuse modules that are 25A. they are fine. Seems strange both are out ?? Any other ideas or suggestions ??
