Fuses. I Need A Chart Of Location
Old Mar 3, 2012 | 12:20 PM
Bertram Wooster's Avatar
Default Fuses. I Need A Chart Of Location
What Ho Chappies
I am trying to figure where and what fuses locate in the boot fuse box.
It would appear that in an attempt to increase dividends to shareholders, Jaguar put a sticky label thingie on the fusebox cover.
However, this has vanished and Jeeves and I have a bit of a problem.
Is there anywhere I can find a fuse chart for the dashed thing.
XK8 2000. and all that.
What Ho
Bertie
Old Mar 3, 2012 | 12:23 PM
Tell Jeeves to look in the FAQ's
Unless you have a handbook in the jolly old glove box, then he could look there.
Old Mar 3, 2012 | 12:48 PM
Dash it all Norri
The manual in the glovebox tells a jolly good description of the number of the fuse, the ampereage and the like but it just doesnt show physically the layout of the box.
I will check the FAQ area however.
Ta
Old Mar 3, 2012 | 12:55 PM
2000CAXK8's Avatar
starts on page 4-14
Megashares - Drag. Drop. Yup. The first site to provide FREE file hosting with drag n drop support.
Old Mar 3, 2012 | 01:05 PM
Indeed a great description, but I need the layout of the fuses in the box. A diagram as you would see looking into the box. Not in my vehicle care manual.
Old Mar 3, 2012 | 01:15 PM
Jeepers Bertie, I hate to say this old boy, but if you can't interpret the descriptions in the book, locations, fuse numbers, function etc, perhaps you need to employ a minion.
Old Mar 3, 2012 | 01:24 PM
Norri
They just dont make minions like they used to.
Your honor, in my defense, I do understand the fuse number, the rating and circuit but with two rows of fuses do the numbers run from left to right or right to left and does the number 1 fuse reside on the end of the top row, or bottom. Dashed if I can see any branding in the box.
Old Mar 3, 2012 | 02:16 PM
Well, I put my spectacles on, took a bright light and low and behold I could see little tiny numbers beside the fuses.
Bit embarrassed here.
What a silly ****.
Thanks to all who responded.
Was checking because my passenger rear window is not closing but stuck half way.
Tootle pip
Bertie
Old Mar 3, 2012 | 02:45 PM
test point's Avatar
If the window is blowing fuses it could be because the operating cable has become entangled. This was a common problem due to the flexing of the winding frame only fixed after about 4 years of field trials. Jaguar must use their customers for more design testing than any other car manufacturer.
Old Mar 3, 2012 | 03:17 PM
What a silly ****.
Tootle pip
Bertie
Jolly good, I knew you would twig eventually.
Seems Jaguar may have seen the value in using minions.
hoodun
Nov 20, 2022 02:35 PM
jimforrest (uk)
Feb 28, 2019 06:42 PM
jorgef858
Jan 14, 2016 11:32 AM
damienedwards
Nov 22, 2015 10:51 AM
waynepaulj
Oct 2, 2015 04:05 PM
