Gearbox fault
Old Oct 31, 2025 | 07:03 AM
Tercel's Avatar
Default Gearbox fault
I wonder if someone can help me I have an
XK8 1999
With a gearbox fault that started when I went around a corner at reasonable speed and I heard a very high pitch whizzy noise and then the box went into limp. Intially I got P0733 - 3rd gear incorrect ratio but after clearing the fault with SDS I got c1095 second gear incorrect ratio. The symptoms are the same - very juddery acceleration then limp.
The further complexity is this has happened whilst I have had a TRAC and ABS failure due I think to the usual module issue. I see on the web that sometimes this can confuse the box.
Could this be low transmission fluid, the related ABS module issue or mechanical gearbox failure and where should I start diagnosing.
Old Oct 31, 2025 | 08:58 AM
RJ237's Avatar
C1095 is a common ABS error. The repair is to resolder the two contacts for the ABS pump motor. A search of the forum will provide instructions or you can send the module to a repair service.
Check the level of the transmission fluid, instructions can be found with a search of the forum.
Old Oct 31, 2025 | 09:10 AM
Tercel's Avatar
yes I have the work to do on the ABS but my question is can
low Transmission fluid
ABS fault code c1095
cause the two fault codes p0733 and p0732 or is this more likely a gear box out and rebuild ?
I am trying to work out if it is worth me jacking up the car and doing the fluid change/top up from axel stands plus fixing the ABS ror in reality this needs a full rebuild costing more than the car thus avoiding the work and sending it away.
thanks
Old Oct 31, 2025 | 09:16 AM
michaelh's Avatar
Could be low fluid, and check your rear wheel bearings.
Old Oct 31, 2025 | 10:28 AM
motorcarman's Avatar
Info for you.
File Type: pdf
Old Oct 31, 2025 | 10:47 AM
Tercel's Avatar
Thanks thats great.
On the wheel bearings. I guess just lift the car and look for excessive play. or is there further diagnostic for this ? Also strange that the bearings would impact gearbox with diff in the way ?
On transmission - Is there an easier way of topping up transmission fluid through say the cooler pipe ?
thanks
Old Oct 31, 2025 | 12:36 PM
michaelh's Avatar
Appreciate it's a bit of a stretch, but "I heard a very high pitch whizzy noise and then the box went into limp." after a fairly energetic cornering made me wonder if it came from an ABS ring making contact with something it shouldn't, and I recalled razorboy's journey with a transmission issue that turned out to be something completely different. His is a 6HP box and not the 5HP you have, but see what you think of his his summary here:
https://www.jaguarforums.com/forum/x...7/#post1919626
You can check rear bearings with the car off the ground:- a little play in the vertical direction (6 o' clock to 12) is OK, but there should be none in the horizontal.
Old Oct 31, 2025 | 01:13 PM
Tercel's Avatar
very interesting - definitely worth doing next. Appreciate the help. Will update when I have checked. Thanks
Old Oct 31, 2025 | 03:09 PM
RJ237's Avatar
You can add fluid through the cooler line, but you still have to remove the fill plug with the engine running, in neutral, gearbox temp 30-50 C to check level.
Old Nov 5, 2025 | 05:05 AM
Tercel's Avatar
Its not the wheel bearings I am afraid. Will check fluid level and revert.
my1fant
Sep 11, 2019 01:36 AM
Ran
Diesel variants - All models
16
Apr 12, 2018 04:41 PM
landmannnn
Dec 8, 2014 01:09 AM
Mikey Musson
Aug 13, 2013 07:11 PM
chupacabra
May 18, 2011 07:58 AM
