gearbox top up problem
Old May 3, 2023 | 05:04 AM
Bill Field's Avatar
Default gearbox top up problem
I think i am low on fluid on my 2000 xk8 4 litre When i brake hard or corner hard transmission looses drive for a second or two then all is good again .I tried to top up the gearbox with the engine warm and running but when i remove the filler plug fluid pours out not allowing me to put anymore in . What am i doing wrong as car is now worse ?? Thanks
Old May 3, 2023 | 08:50 AM
motorcarman's Avatar
I fill/check the ZF 5HP24 cold (30 Centigrade) because warmer is a lower fluid level.
I start the process BELOW 30 so the level is correct AT 30.
Old May 3, 2023 | 12:28 PM
zray's Avatar
Is it just the traction control engaging ?
You can turn that off to verify it’s not what you are experiencing.
z
Old May 4, 2023 | 12:20 PM
barnter's Avatar
The pump in your transmission may be failing. Are there any codes from the TCM?
sala7
Jun 13, 2022 06:45 PM
asjdhsajhdfj
May 15, 2022 03:05 PM
HermesGovantes
Mark V - X 420G
Jun 15, 2021 10:53 AM
timskipper
May 16, 2021 10:41 AM
Mr. Barry
E type ( XK-E )
Nov 18, 2014 07:45 AM
