GEARBOX (TRANSMISSION) FAULT error P1722
Hello,
I am testing my XK8 which I recently restored. Today I drove for about 10 miles on smooth roads and everything went well, perfect engine and gearbox. Returning to my downhill village. Having to give priority to a rising vehicle, I had to stop and reverse for a few meters. Returning the gearbox to D to continue I heard a "clunk" then GEARBOX FAULT on the display and the car was no longer moving forward. Off and on again and everything worked. I therefore walked the streets of the village for a few more miles to see if there were still problems. All quiet. I then reproduced the same situation, reverse downhill: same result, clunk! I read the error P1722. Where do you think I start the diagnosis? Could it be the fault of a low level of the gearbox fluid?
yesterday I put the car on the lift and got ready for the refill. I opened the fill plug with the engine running and the oil sump which measured 35 degrees celsius. Surprisingly, half a glass of oil came out. Apparently there was too much oil ... I tried the Jag after this work and even replicating the descent experiment everything went well. The gearbox shifts smoothly in any situation. Do you think this is a coincidence or is it possible that that excess of oil caused that malfunction?
campaign308
May 27, 2014 03:41 PM
