green oil drip from front header...
Old Jul 21, 2011 | 05:50 PM
deadboy1977's Avatar
Default green oil drip from front header...
2003 xkr conv, guess I am a lucky one too, ugh
where is the best how to on here with pics and all?
also do i just need to replace the hose set goin to the latch since thats where the leak is??? Should I replace the other 2 sets that lift the top while I am doing this? What do most people do?
Should I relieve the P by opening the petcock on the oil reservoir?
Old Jul 21, 2011 | 07:44 PM
test point's Avatar
Many discussions on this subject. See the FAQ sticky above which is sorta in alphabetical order for more information than you will ever need. While there understand and install one of the two solutions so that this doesn't happen again.
Most folks only replace the latch hoses.
After reading up on that come back with further questions.
Old Jul 21, 2011 | 08:10 PM
yes most just do the latch hoses i see that
most dont seem to replace the latch (I think)
and you can splice or run full new hoses
i see no mention of what temp measures to do
open petcock?? not sure how to release pressure until a fix is done
the top is in the up position
it happened today maybe cause its 102 out? no idea
Old Jul 21, 2011 | 08:30 PM
Gus's Avatar
Gus
Go to my page and you will find all you need to know. This link will get you started Roof Hose Evaluation Hope this will help!
Old Jul 22, 2011 | 09:15 AM
Reverend Sam's Avatar
If you already have the drip, the green shower is not far behind. I think you need to quit using the convertible top altogether until you replace the latch hoses. Then, install Gus's pressure relief valve or the pressure limiting resistor to prevent (or at least delay) future hose failures.
You're lucky you got the slow drip. Most people never have the drip and just get the sudden hose failure.
Old Jul 22, 2011 | 11:01 AM
WhiteXKR's Avatar
Without an inspection of the area, you cannot be sure if it is a hose or the latch that is dripping.
bamforp
Aug 14, 2024 05:36 PM
kelliott
May 31, 2022 05:26 PM
Dymaxxion
Sep 4, 2015 02:40 PM
bdboyle
Sep 4, 2015 06:16 AM
Jag-o-nomic
Sep 4, 2015 03:07 AM
