Grinding noise.. S/C or aircon compressor
Old Sep 22, 2013 | 02:17 PM
steventoon's Avatar
Default Grinding noise.. S/C or aircon compressor
Hi
I've had a grinding noise now for a few months that sounds very like the metal on metal sound when your brake pads are worn. When serviced in August Jaguar said it was the supercharger and not too worry at the time but eventually it would need replacing. Apparently they need changing circa the 100K mileage mark. Mine has done 97k.
Ive just been up to London and back and it has become considerably worse. I sourced a decent second hand supercharger and have stripped the top down as per the guide in growler.
However I'm now wondering if the noise could be a tensioner or idler pulley or has anyone had any problems with the aircon compressor pulley. The inside of the pulley seems to pull out independantly of the bit where the belt goes and I can imagine this is giving the metal on metal noise.
Is replacing an ircon compressor a DIY job? The first photo shows what I believe is the air con compressor pulley, the second photo is of the idler pulley from my supercharger belt. Not sure what the black is on the surface ! Maybe time for a change.
Thanks in advance
Steve
Attached Thumbnails Grinding noise.. S/C or aircon compressor-pulley-1.jpg   Grinding noise.. S/C or aircon compressor-pulley-2.jpg
Old Sep 22, 2013 | 07:00 PM
The Drive Belt Tensioner (item 2) is a known failure.
Grinding noise.. S/C or aircon compressor-drive-belt-tensioner.jpg
Eliminate that before jumping to the more expensive belt driven components.
Old Sep 23, 2013 | 06:18 PM
MarcB's Avatar
+1 on Graham's direction about eliminating less costly components! It was really noticeable at start up but when it warmed up it was quieter (heat expanding the metal). I was eventually able to determine it was the idler pulley as I shot some WD-40 in behind it and the noise subsided temporarily. It was replaced at 108K miles.
Old Oct 2, 2013 | 05:56 AM
steventoon's Avatar
Thanks for the replies. I know it's not the supercharger, or idler / tensioner on that side of things.
I'll try the idler and tensioner. If the belt is removed is there anyway of telling if these items are u/s or is it just replace and see?
Steve
Old Oct 2, 2013 | 08:39 AM
batroute's Avatar
Steve
With the belt removed check for free play and noise in the rotating parts - check the alternator as well - they can screech if the bearings are on the way out. In your original post the a/c compressor has an electromagnetic clutch at the front - that could be what you're thinking is loose, from your description it sounds normal.
Old Nov 12, 2013 | 11:31 AM
steventoon's Avatar
Smile
Thanks for the help. All sorted. It was the aircon compressor pulley that was broken and wobbling on its shaft.
Steve
Nic1635
Oct 2, 2015 01:30 AM
Lawrence
XJ40 ( XJ81 )
Oct 1, 2015 08:36 AM
dan102877
Sep 29, 2015 06:47 PM
ChrisJay
Sep 27, 2015 09:08 AM
