Handbrake Button Stuck
Old Jan 7, 2025 | 04:43 PM
glen1497's Avatar
Default Handbrake Button Stuck
Hey everyone,
I'm having trouble with my Jaguar XK8's handbrake. When I lift it to release, I'm unable to push the button in. The button is literally not pushable. Has anyone else experienced this? Any advice on how to fix it would be greatly appreciated as I want to take it for a spin but as the handbrake cannot release, it’s not moveable.
More info:
The hand brake is floppy (which it supposed to be), I lift it with no force then it stops, then I can use all my strength to pull it up but the button is not pushable.
Not many people here in New Zealand know what the fix is ughhhh
Thanks in advance!
Old Jan 7, 2025 | 07:00 PM
baxtor's Avatar
Originally Posted by glen1497
Hey everyone,
More info:
Thanks in advance!
When you say "not pushable" do you mean access to button is fine but it is stuck fast, or do you mean the button is not accessible.
If the latter it may be that the push on handle has moved, making the button inaccessible, push the handle back into place to expose more of the button.
Old Jan 7, 2025 | 07:25 PM
glen1497's Avatar
Hi,
Button is accessible, just not pushable. I’m going up to the car next weekend so I’ll take pics and a video.
Old Jan 8, 2025 | 05:01 AM
RichardS's Avatar
It is not difficult to access the handbrake mechanism by manoeuvring the seal on its electrics until it is as out of the way as possible. The plastic cover just unclips with two clips and slides out of the way but check online/in the manual exactly where the clips are as you don't want to damage it. It's easy once you've read how to do it.
If necessary, you can easily unbolt the entire handbrake mechanism, only two (and one more for the pivot) 10mm bolts as I recall, and see what is happening and oil it as necessary. Start by loosen the cable at distribution fitting under the car further back between the two resonators to allow easy removal of the latching mechanism at the handle. After this the car will be driveable again provided you don't mind not having a parking brake.
Richard
Old Jan 9, 2025 | 04:00 PM
blindside's Avatar
I believe you just have to pull it up a tad more and then the button will release so you can push it in again.
drollie
Dec 22, 2024 05:27 PM
Josh1996rx7
Oct 10, 2022 10:06 AM
Nigel Holmes
Feb 15, 2021 06:39 AM
RoVerto
General Tech Help
Sep 29, 2019 08:43 PM
EnjoyEverySandwich
Apr 16, 2019 11:48 AM
