Handbrake help please
Old Apr 2, 2014 | 08:34 AM
Avrs's Avatar
Default Handbrake help please
I guess I'm missing something obvious but even with the car in N the rear hubs won't rotate to access the adjustment pawl. Is there some kind of locking mechanism I need to release?
All the info I can find online simply says rotate the hub until the adjustment pawl is visible.
I need to get the discs off. Pulling my hair out! What's left of it.
Del
Old Apr 2, 2014 | 08:47 AM
RaceDiagnostics's Avatar
Assuming the hand brake is off, you could use a bit of gentle leverage from a wood pole between a couple of the studs, if the pads are binding a little.
Old Apr 2, 2014 | 08:54 AM
Avrs's Avatar
Thanks. I did give that a go but it feels like it is locked in park constantly.
The hubs will turn if you start the car and put it in drive, but the handbrake is dragging badly.
I thought perhaps there was some kind of safety locking mechanism in play here.
Old Apr 2, 2014 | 09:03 AM
batroute's Avatar
Have you released the handbrake correctly? The release mechanism sometimes fools people not familiar with a lie flat handle - alternatively is the cable seized?
Old Apr 2, 2014 | 09:07 AM
jimbov8's Avatar
Don't wish to offend Derek, but are you sure the handbrake is actually released.
Lift the lever, if there is no tension then the handbrake is on.
This took me a little time to get used to when I bought my XJS.
Hope this helps,
Batroute beat me to it.
Old Apr 2, 2014 | 11:58 AM
Avrs's Avatar
Yep. Thanks for that. The part of the mechanism between the handbrake lever and the quadrant wasn't releasing fully. I sprayed WD40 in every place I could, loosened it at the yoke and yanked the handle about 50 times really fast and eventually it freed itself. Not sure why it would stick at that part of the mechanism as its inboard and technically in the dry.
Really good news
Thanks for the help guys.
Old Apr 2, 2014 | 01:04 PM
Del,
If the handbrake mechanism has been seized on, the shoes will have been wearing down.
Normally they last for ages because they are only in contact with the inside of the hub with the vehicle stationary and there's no rotation to wear the friction material.
Provided the handbrake releases OK now and holds the vehicle on an incline, there's no immediate rush but it's one to add to the list when you come to service the rear brake pads and discs.
Old Apr 2, 2014 | 02:30 PM
Avrs's Avatar
Yep. Definitely needs further attention in the future. Will give it a complete overhaul later with new cable and shoes but at least now it can go for an MOT.
Just out of curiosity, how easy is it to get to the mechanism under the carpet behind the drivers seat? Looks like the whole rear trim panel needs to come out to release the carpet enough. Also how are the chrome sill trims held in place?
Old Apr 2, 2014 | 02:46 PM
Originally Posted by AVRS
........ Looks like the whole rear trim panel needs to come out to release the carpet enough. Also how are the chrome sill trims held in place?
Good luck for the MoT.
To do anything with the carpet, the front seats and the centre console have to come out.
The 'Jaguar' plate on the sill trims is glued in place and the sill trim itself has fixing screws. See post #2 in this thread for removal details:
https://www.jaguarforums.com/forum/x...esolved-81964/
Dave1109971
Dec 15, 2015 06:16 PM
Pluckie
Oct 3, 2015 07:57 AM
RollaJones
Sep 27, 2015 03:31 PM
Roger95
Sep 25, 2015 02:05 PM
