Hard reset on 2006 XK8
Old Jul 21, 2018 | 02:07 PM
65Pontiacnut's Avatar
Default Hard reset on 2006 XK8
Does anyone know if a hard " Reset" will work to clear codes on 2006 XK8? By hard reset i mean taking off the battery cables & touching the 2 disconnected ends together. I already tried it once ( didn,t work) Now i,mn told to also blow horn & turn on lights With battery disconnected as the
re is/are capacitors that retain codes when battery change is made. BTW, I have fixed most if not all of the known issues. I don,t want to have to buy new parts for the car. Any help will be appreciated. Thanks
Old Jul 21, 2018 | 05:23 PM
Welcome to the forum 65Pontiacnut,
A hard reset will only clear 'learned adaptions' such as fuel trims and window travel limits. It is not a procedure for clearing DTC's. I recommend you post the codes for advice on how to resolve them.
Old Jul 22, 2018 | 10:58 AM
JagV8's Avatar
If the faults are fixed the MIL will go off (after 3+ warm ups) and later on the codes will be auto-erased. No need to do anything.
JimC64
Sep 22, 2025 02:52 PM
Poet
Apr 11, 2022 06:51 PM
chillyphilly
Nov 10, 2017 11:49 PM
joesoap
Oct 31, 2017 10:13 AM
o2manyfish
Oct 30, 2017 02:11 PM
