Harmon kardon amplifier dead? Worth attempting repair?
Old May 15, 2011 | 04:34 PM
jagosaurus's Avatar
Question Harmon kardon amplifier dead? Worth attempting repair?
Suddenly there was no sound, and the CD changer would not turn on (as it's powered by the amp). The headunit powers on just fine.
Does the amp have an external fuse? Could it be easily repairable? Should I just order a new used amp for $100? I also had some issues with the volume dropping down, especially in cold weather?
Cheers!
Old May 15, 2011 | 08:49 PM
WhiteXKR's Avatar
The HK amps were wired on the same fuse as the power antenna. If your power antenna rises, its not a fuse.
Old May 16, 2011 | 05:57 AM
MicksJag's Avatar
jagosaurus, I have an amp if your unable to get yours to work. Just let me know. Micksjag.
Old May 17, 2011 | 03:30 AM
jagosaurus's Avatar
Thanks, checked fuse 9 in the trunk, no problem with it. I have a new amp on the way, so ill test that one first!
Old May 17, 2011 | 09:31 PM
jagosaurus's Avatar
Replaced the amp, made sure the antenna moves and the radio receives a signal (ST lights up), but still no sound. Cd changer not connected, but if I try to connect it I can't switch to it. What gives??
Old May 17, 2011 | 09:49 PM
WhiteXKR's Avatar
Double check both radio fuses: #9 and #12 on the passenger side fuse box. One is battery power and the other is ignition power to the headunit.
Old May 18, 2011 | 01:16 PM
jagosaurus's Avatar
Both fuse 9 and 12 passenger side are fine. And the headunit powers up. Strange!
Dagny
Jun 11, 2024 01:06 PM
2001 White XJ8
Feb 25, 2021 05:02 PM
drewlabarbera
Sep 14, 2015 07:46 PM
sonofdave1980
Sep 14, 2015 07:45 PM
Bones
Sep 8, 2015 08:34 PM
