which head gasket
Old Oct 18, 2020 | 06:58 PM
stevepaa's Avatar
Default which head gasket
should I use Jaguar brand or Payen or Eurospare for 2001 xk8 NA? There seem to be some with red sealant and some with black sealant around oil passages.
Old Oct 18, 2020 | 07:27 PM
RJ237's Avatar
Several members have used the 4.2 mls gaskets. You might want to do a search, or maybe someone will respond with more info.
Old Oct 18, 2020 | 07:47 PM
motorcarman's Avatar
I have been using the later 'multi-layer-steel' gaskets for all the replacements for 4.0 and 4.2 engines.
Old Oct 18, 2020 | 09:24 PM
pdupler's Avatar
On those lesser expensive aftermarket ones, that line of red sealant is very fragile and its easy to accidentally nick it and scrape off a spot. And you won't know you did until you put it all back together, fill it with fluids and start it up.
Old Oct 18, 2020 | 09:50 PM
xalty's Avatar
Use the steel one sold for the 4.2L V8, even if you have an NA motor.
Old Oct 19, 2020 | 12:17 PM
stevepaa's Avatar
I am looking at the latest AJ88987 and AJ88988 and wondering if the PAYEN is the maker of the the head gaskets for Jaguar.
https://www.autohausaz.com/pn/PY-AJ8...SABEgJhl_D_BwE
Old Oct 19, 2020 | 01:02 PM
That price beats Parts Geek.
Old Oct 19, 2020 | 02:15 PM
stevepaa's Avatar
Any reason to buy from dealer? Is this one the same as dealer?
thanks
Old Oct 23, 2020 | 12:07 AM
Hdpartsman00XKR's Avatar
The Payens are definitely the better quality aftermarket gaskets. The 4.2 mls gaskets such as these will work splendidly on your 4.0.
Cheers, BK
BadDog
Dec 3, 2021 06:47 PM
Evil Elsie
XJ40 ( XJ81 )
Sep 20, 2019 02:41 PM
AnttiM
Apr 20, 2018 02:23 PM
Muleears
XJ40 ( XJ81 )
Nov 13, 2010 09:14 PM
