Header panel cloth
Old May 22, 2012 | 02:10 PM
randyb's Avatar
Default Header panel cloth
I need new cloth for my header panel, I had grease on my fingers and grabbed the panel and compounded the problem when I put to much cloth adhesive on and it soaked through the material.
So where can I get match color cloth or preferably pre-cut cloth?
Old May 22, 2012 | 02:17 PM
Spurlee's Avatar
Default Headliner Material
You can get the basic colors (Black/Grey) at any fabric store. They will also sell the spray adhesive.
The old material will peel right off and you can use a stiff brush to remove the (probably) dried out foam backing. The new headliner is stretchy and will easily form to the shape.
I replaced the A-pillar portions, too so that it was a good match. Mine was grey originally but I replaced it with black which is much more attractive IMO.
An easy DIY project.
Old May 22, 2012 | 02:43 PM
randyb's Avatar
Forgot to say that my interior is Oatmeal.
Old May 22, 2012 | 05:07 PM
H20boy's Avatar
theres a post that someone added to a material thread that specifically identified a great 'oatmeal' match, try a search with those words, see what you find in this subforum.
Old May 22, 2012 | 05:53 PM
randyb's Avatar
Thanks, I think from now on when I do a search, I am going to put Rev Sam in with my other search parameters.
Old May 23, 2012 | 08:00 PM
vettegood's Avatar
Hello, I am going to do the A-pillars (where did that name come from, anyway?) and I was thinking about doing the header as well so the pillars and header match.
Is there specific method to getting the header off?
Just do the screws and it comes off, no hidden problems removing header?
What about the visors, they would not appear to be an easy upholstery job as there are several heat seals or seams that cannot be reproduced.
I am planning to do the pillars and header in a tan material that does not match the existing dove gray material.
I changed the headliner to tan as well, much better color match for my interior, but of course now it does not match pillar, header or visors. If I do the pillars and header all will match except the visors!
Thanks for any thoughts or knowledge to make this job a DYI.
Happy Motoring...
Old May 23, 2012 | 08:51 PM
WhiteXKR's Avatar
Happy Motoring...
A-pillars: http://www.google.com/imgres?q=a+b+c...QHbp6lj&zoom=1
To remove the header, remove the A-pillars, then disconnect the battery. Pull down and unplug the ceiling console, then all the visor screws and brackets.
Biggest caution is on re-installation: do not get the visor light wires pinched under a screw or clip (it is easy to do). There is a design fault in the Body Processor Module and this particular short can cause complete module failure rather than a fuse blowing like it should.
Automotive sunvisors recovered to like new conditions : WLS Headliners. recovers sunvisors. I have no idea as to the quality of their work though.
Old May 23, 2012 | 09:10 PM
vettegood's Avatar
Thank you, Thank you and Thank you!
WhiteXKR, Great info and links. Very much Appreciated.
I will let you know what I find out about sunvisor recoverers and what I did with the DYI upholstery.
Did I say Thank You?
Happy Motoring.
Old May 27, 2012 | 04:30 PM
vettegood's Avatar
Default Fyi
Hello WhiteXKR, thanks for the info again.
FYI, just to let you know I called WLS headliners about what they do for sunvisor and they won't do a Jaguar XKR convertible sunvisor, because they have been heat sealed on the edges and they cannot do that and won't sewn a seam because they say it would not look professional. That is there statement! Oh well...
I may just remove them I do not like their looks much anyway and with the top down they do not do a lot to help with sun..
Old Jul 9, 2012 | 09:16 AM
jagjer55's Avatar
i went to a local upholstery shop that does classic and modern cars with a sample of my a pillar coverings and they came up with a close match. cost me 5 dollars for enough material to do both a pillars and the header panel
n8ertot
Oct 11, 2015 02:28 PM
convincor
Oct 1, 2015 05:19 PM
Long Islander
Sep 27, 2015 03:45 PM
HuncaMunca
Sep 27, 2015 02:47 PM
