Headlamp washers
Old Jul 24, 2018 | 06:40 PM
alanroberts50's Avatar
Default Headlamp washers
I would like to pull the fuse to stop them! Does anyone know where it is and if it's a solo fuse or if anything else runs through that fuse?
Old Jul 24, 2018 | 06:55 PM
michaelh's Avatar
Pull the relay: #4 Engine compartment fusebox:
Old Jul 24, 2018 | 07:20 PM
Thanks, so can I just pull that relay or will it affect the windshield washers too?
Old Jul 24, 2018 | 07:34 PM
michaelh's Avatar
Hi,
The windshield washers have a separate pump so you're OK.
Just looked a little closer: you could pull fuse #7 in the same fusebox instead. Might be easier to replace a missing fuse rather than a relay if your filing system is as bad as mine
Mike
Tango Nevada
Apr 16, 2018 04:56 PM
rkindon
May 6, 2014 02:45 PM
flyrr100
Nov 17, 2012 04:35 PM
04XJwpg
Feb 18, 2012 12:21 PM
andriy
Jun 8, 2011 02:31 AM
