headlamps
Old Jun 24, 2014 | 10:16 AM
Bleujag's Avatar
Default headlamps
Finally the car is repaired with a lot of second hand parts and is ready to go for technical inspection.
When adjusting the headlamps we found the left lamp not be able to allign for a european car. The lamp looks to be an english version.
So before we take the lamp out we would like to no know if there is a adjustment on the lamp to make it european or I need to replace the headlamp again?
Old Jun 24, 2014 | 10:27 AM
Bleujag's Avatar
It is for a 2000 model without washer.
Old Jun 24, 2014 | 10:36 AM
There's not a simple adjustment. The dipped beam is set by the shape of a plate fitted inside the headlamp assembly:
LHD Conversion plates are often listed on eBay at around £80 a pair. I recall reading it's possible to cut a RHD plate to LHD shape to get the correct dip.
Old Jun 24, 2014 | 11:28 AM
Bleujag's Avatar
Thanks for the helpfull reply .
Would it be an option to remove that plate from my damaged (only the adjusters where broken off) headlamp and replace it in the english headlamp?
Regards,
Luc
Old Jun 24, 2014 | 12:50 PM
Luc,
The RHD/LHD plates have exactly the same fixing holes so that should be the simplest solution.
Here's a thread from Europe Region forum about headlamp conversion on imported XK8's to pass the French CoC that may be of interest:
https://www.jaguarforums.com/forum/x...-change-68469/
rentzoo
Nov 10, 2015 04:56 PM
puddled
Sep 22, 2015 03:57 AM
Samheath100
Sep 17, 2015 10:03 AM
Na5h
Sep 11, 2015 07:26 AM
