Headlight.
Old Mar 29, 2023 | 01:08 PM
Ant Buck's Avatar
Default Headlight.
The next job is the drivers side headlight that thinks it's a swimming pool. I thought initially it was getting in through the clear cover on top of the light unit, so i fitted a piece of flexible plastic larger than the cover over the top . Is there somewhere specific i should be looking. Many thanks. Anthony.
Old Mar 29, 2023 | 02:55 PM
motorcarman's Avatar
TSBs are your friend.
File Type: pdf
File Type: pdf
File Type: pdf
Old Mar 29, 2023 | 03:50 PM
Pistnbroke's Avatar
The main area is the water shoot that comes along the wing .make sure its in place .
Next is to push the white plastic cover down by putting a wooden bloc or wedge between it and the body to push it down, You can also put a large bag of desiccant under the plastic lid Main thing is the plastic shoot... Dry it out with a hair dryer
We should meet up we are only 10 miles apart.
OldCoastie
Sep 8, 2021 10:30 AM
turbo68
Mar 11, 2011 09:36 AM
Eric
Nov 29, 2009 06:38 PM
thedustroom
Jan 25, 2009 04:22 PM
