Headlight removal, condensation
Old Jul 20, 2013 | 05:08 PM
Alan E L's Avatar
Default Headlight removal, condensation
Hi all,
My RH headlight suffers from condensation after the briefest exposure to water.
I presume the water is entering via the glass to housing seal.
Would it be best to remove it to attempt to reseal?
How is the headlight removed? I don't want to break anything.
Can the light be fully disassembled?
Is this the way to go?
The lights are the earlier halogen type, can brighter/ better globes be purchased?
Is there anything else I should know?
Thank you for any and all assistance, anecdotes, advice and encouragement.
Information provided by this forum makes ownership of the XK8 so much easier
Al
Old Jul 20, 2013 | 06:01 PM
Al,
Condensation is a regular issue. There's a vent pipe can be retro fitted to minimise this:
417 05 - Headlamp Misting.pdf
However, it still doesn't entirely prevent condensation.
The seal between the glass and the headlamp body is also known to fail allowing water into the headlamp unit. The headlamp has to be removed to rectify this.
Is it condensation or seal failure on yours?
Old Jul 21, 2013 | 12:14 AM
Alan E L's Avatar
I believe it is an actual leak, a good wash or drive through some weather and it gets wet, then of course condenses on the glass
Al
Old Jul 21, 2013 | 03:21 AM
Here is the JTIS procedure for LH headlamp removal:
JTIS - XK8 Headlamp Assembly - 1997.pdf
RH is the same sequence.
The Parts Catalogue has the best illustration of how the headlamp lens attaches to the shell with slotted tabs clipping over raised mouldings:
(click on the diagram to enlarge it)
You'll get the idea of how to lift these with a screwdriver to release once you can see them.
VRB
Sep 15, 2015 08:18 AM
1964Daimler
Sep 9, 2015 11:28 AM
avern1
Sep 8, 2015 06:25 PM
avern1
Sep 6, 2015 04:22 PM
laserguy
Sep 3, 2015 02:02 PM
