Headlight Washer
Old Dec 29, 2009 | 09:34 AM
Jag69's Avatar
Default Headlight Washer
All,
Just recently the left headlamp washer is squirting above the lamp and onto the windshield. Can the washers be aimed?
Thanks in advance.
Old Dec 29, 2009 | 12:15 PM
H20boy's Avatar
doubtful, i'd check and make sure its not damaged or partially blocked. Be careful...don't break it.
Old Dec 29, 2009 | 02:12 PM
stremsjg's Avatar
Yea, I have the same problem with the right headlamp washer. How do you make any adjustments to the washer head? Are you able to manually pull the washer head out and make adjustments to the spray aim?
Old Jan 1, 2010 | 07:36 PM
2000blackxkr's Avatar
Wink washer
am i the only on who ends up rolling over laughing whenever the things spray the lights? i mean what's the point of spraying the head lights when you don't have a wiper on them?
Old Jan 1, 2010 | 09:08 PM
Brutal's Avatar
if you pull out the washer, youll find that 1 or both of the nozzles popped out and now you need to replace the assembly....
And no youre not the only 1 to laugh Black, I find the only thing theyre good for is messing up a clean car when all you want to do is clean off the windshirld alittle
Old Jan 2, 2010 | 05:15 AM
Brian2000XKR's Avatar
"I find the only thing they're good for is messing up a clean car when all you want to do is clean off the windshield a little"
When I first got the Jag, I thought "How cool!". Now, I dread them coming on and find them totally unnecessary, at least for my driving location. Eventually I'll probably remove a fuse or something to stop them from messing with my wax jobs....
Brian
Old Jan 2, 2010 | 10:08 AM
Brutal's Avatar
you can unplug the pump for them cause the fuse probobly controls both pumps
Old Jan 2, 2010 | 11:19 AM
Hey Brutal,
Thanks, that sounds like a great idea!
Brian
Old Jan 2, 2010 | 01:15 PM
GreenJewel's Avatar
Are these "secondary windshield washers" automatic or do you have to press something to make them come on and squirt?
Old Jan 2, 2010 | 02:32 PM
Brutal's Avatar
going off of memory(disclaimer) I believe they only come on with headlights on auto or on and you hit the washer button. But if in doubt or to know for sure since Jaguar likes to change things from year to year and model to model........
Old Jan 2, 2010 | 04:01 PM
GreenJewel's Avatar
Originally Posted by BRUTAL
Ha ha.. RTFM... I have the "Cheap" model XK8... no secondary windshield washers, nothing about them in my FM.
I thought you were going to consult that Christal Ball that's in your garage.
Old Jan 2, 2010 | 04:17 PM
Spitfire's Avatar
I discovered that my headlight washers are activated every sixth time you push the washer button. Not sure why this is. Guess I have the RTFM too! Lol!
How did I discover this? I was rolling around on the ground laughing too when they come out and wanted to see it again. LMAO! I have an S type mind you so don't know if there is a difference between types.
Cheers!
Rob
Old Jan 2, 2010 | 07:21 PM
Gus's Avatar
Gus
Hope this helps.
Old Jan 3, 2010 | 09:12 AM
Jag69's Avatar
Default Headlamp Washers...
Thanks for the advice and confirmation of what I also thought was a design short-coming!
Although they did not make me laugh when I first saw them operate, I did find them useless. That being said (although I like everything to work...I'm funny that way) now that they do not work, they are not effective, mess up the newly waxed hood and its not an easy fix, I may just let them be.
Old Jan 3, 2010 | 09:36 AM
Gus's Avatar
Gus
What fun is that?
Old Jan 3, 2010 | 12:07 PM
Brutal's Avatar
I think I have a new 1 at work, Ill have to check. They suck getting the new ones in. Theyre the type job that sometimes they snap right in first try, other times you j u s t c annn' ttt get th e s t u pi dddd sob in argghhhh
Old Jan 3, 2010 | 02:08 PM
Gus's Avatar
Gus
Now if you are looking for headlight washer parts I am looking for a cover for my left washer cover. If you have one let me know.. 99xk8
Attached Thumbnails Headlight Washer-img_0243.jpg   Headlight Washer-img_0244.jpg
Old Jan 3, 2010 | 07:50 PM
hlgeorge's Avatar
Driver side or Passenger side? US
Old Jan 3, 2010 | 07:52 PM
hlgeorge's Avatar
I disconnected the headlamp washers on my '88 Rolls Royce. All they did was water spot my bumper!! Easier to wipe them off with a wet paper towel occasionally! LOL
Old Jan 3, 2010 | 07:58 PM
Gus's Avatar
Gus
Drivers US
