Heated Windscreen
Old Dec 18, 2011 | 06:29 AM
Default Heated Windscreen
There's no signs of life in my heated windscreen although the button on the climate control pack lights up. Rear screen and door mirror heating does work.
I've checked the 30 amp Fuses 15 and 17 in the Engine Management Fusebox for left-hand and right-hand windscreen heaters - both are OK.
Earlier XK8's had separate Driver and Vehicle Care Handbooks and the latter usefully listed relay functions and locations. This car has a single Handbook combining the two but this has no information on relays.
The heated windscreen automatically switches off after six minutes. There must be one or more relays and a timer to control this. Anyone have information on the circuit layout and location of the control components?
2005 4.2S Coupe
Old Dec 18, 2011 | 07:19 AM
itspec60's Avatar
This is what I found in JTIS for a 2003. Hope this helps.
Old Dec 18, 2011 | 07:33 AM
Jag13cat's Avatar
Default GGG - Windscreen Relays
The windscreen relays should be on the right hand side of the vehicle, just in front of the hood (bonnet) release spring, covered by a black cover box approx. 4 inches long. The front one is the starter relay, followed by the LH and RH relays. The LH will have a green/white wire going to the heating element, while the RH will have a green/orange wire going to the heating element
Old Dec 18, 2011 | 08:02 AM
Thanks to itspec60 for the graphic and Jag13cat for the further info.
I've lifted the RH black cover:
There is the black box approximately 4 inches long:
How does this open - unclip from the inner wing first or just pull the black cover up? There's no obvious clips on it.
Old Jan 28, 2012 | 09:22 AM
Thanks to itspec60 and Jag13cat for posted help and WhiteXKR for PM.
To summarise for anyone else who may have similar problems, the Heated Windscreen is protected by three fuses and two relays:
Engine Management Fusebox:
No 15 Windscreen left hand heater - 30 amp
No 17 Windscreen right hand heater - 30 amp
Fascia Fusebox- Right hand
No 16 Windscreen heater relays - 5 amp
Relay Box - beneath RH bulkhead cover
Rear Relay JA6703AA (brown) - right hand heater
Centre Relay JA6703AA (brown) - left hand heater
The black cover for this relay box is attached by a single fixing to the bulkhead and just pulls upwards to release and remove. The box contains three identical relays, the one nearest the front of the car being for the starter. If the car starts, the two windscreen relays can easily be checked by substitution with this one.
Both relays should show 12 volts between the Blue/Yellow and White/Red wires when the heaters are turned on.
The thick Green/Orange wire for the right hand heater and chassis ground should show 12 volts when the heaters are on. Likewise the thick Green/White for the left hand heater and chassis ground.
If all this checks out and the screen still isn't heating then it's either broken wires to the screen or bad elements in the screen itself.
Unfortunately it checks out on mine so I'm left with the probability of bad elements.
Old Jan 28, 2012 | 10:16 AM
jamjax's Avatar
3G;
I have a heated windscreen????
Where's the switch for this?
I really do have to sit down and read the entire manual someday.
cheers,
jj
Old Jan 28, 2012 | 10:26 AM
Originally Posted by jamjax
3G;
cheers,
jj
JJ,
Possibly not as they were only a standard fit on the UK 'S' and US 'Victory' models and an option on others.
If you do, the button is to the left of the heated rear screen button.
Old Jan 29, 2012 | 01:08 PM
jamjax's Avatar
GGG;
Well aren't you 'Special' with your S.
No heated windscreen for me...just a defroster button that blows air through the defroster vent where you said the heated screen button would be.
Now I feel left out. Again.
cheers,
jj
Old Jan 29, 2012 | 02:35 PM
GGG;
cheers,
jj
JJ,
You're probably better off without one.
Mine has a problem with the wiring between the relays and screen, Frog recently paid $3000 for a replacement screen and trim.
Old Jan 29, 2012 | 04:35 PM
jamjax's Avatar
GGG;
Thanks, much better now.
Sorry Froggy...hope you are feeling better these days.
cheers,
jj
Old Jun 29, 2015 | 08:53 AM
Vladimir Orekhov's Avatar
Hi guys,
I have bought an XKR 1998 a month ago and now got a stone into my windscreen. The company that will replace it for me asks whether or not I have a heated windscreen. I suppose I have a usual one, but just in case wanted to ask you where to look to double check? I've heard there are some wires at the bottom of the window and also a button to heat it, but if anyone can send me a photo of how it should look like, that would be nice!
Old Jul 2, 2015 | 05:31 PM
Originally Posted by Vladimir Orekhov
I have bought an XKR 1998 a month ago and now got a stone into my windscreen. The company that will replace it for me asks whether or not I have a heated windscreen. .........
Welcome to the forum Vladimir,
If you look closely at a heated windscreen you can see the fine vertical parallel wires embedded in the glass. I've arrowed four of them here:
Difficult to see and even more difficult to photograph!
Old Jul 2, 2015 | 06:49 PM
BlkCat's Avatar
Originally Posted by GGG
JJ,
I have a 2006 Victory Edition and I am pretty sure I don't have a heated windshield. I'll check it I'll look for the button.
Jack
Old Sep 8, 2016 | 03:36 PM
verdeo's Avatar
I've been curious about seeing little vertical distortions in my windshield when the sun is low in the sky and wondered if any XKR's had heated windshields.
Thanks to this thread and GGG for detailing this for me. And, yes I do have the third button on my dash console. Just wasn't sure what it signified!
Always things to learn with the kitties.
Thanks,
Gary
Old Mar 6, 2017 | 07:40 AM
RONALDO's Avatar
My 1997 xk8 has no gauges working warning lights are on and do not go off no rec counter or speedo checked 5 fuse boxes after battery was replaced
Old Mar 6, 2017 | 10:49 AM
bladerunner919's Avatar
Maybe you should start a thread about if, with some more information?
It doesn't seem relevant to this thread.
Old Mar 9, 2017 | 06:56 PM
Wide_Tyres_2's Avatar
My 2004 Quartz XKR has it...
& it works like a charm to melt ice, in no time flat
See the extra switch for defrost it was on All Canadian Jags had it on my 97XK8 too
Old Mar 10, 2017 | 10:27 AM
Welcome to the forum RONALDO,
This thread won't help you with those issues.
Old Mar 12, 2017 | 08:15 AM
zecretw's Avatar
I do not get this..
If you need to defrost the windscreen it is just too cold outside to drive your Jag..
Old Mar 12, 2017 | 11:24 AM
Originally Posted by zecretw
I do not get this..
-2 to +4 deg C in Kristianstad today.
When do you get the opportunity to drive your Jaguar?
aode06
Jul 28, 2023 02:26 PM
Delta66
Oct 4, 2015 05:40 PM
Newark Nj Gang
Oct 2, 2015 02:39 PM
Lawrence
XJ40 ( XJ81 )
Oct 1, 2015 08:36 AM
