Help!! brake rotor from hell
Old Sep 13, 2013 | 03:35 PM
waterloo's Avatar
Default Help!! brake rotor from hell
I finally got around to replacing my brakes on my 06 xk8, But i cant seem to get the front rotors off. I have tried every old trick but nothing works. This has me concerned that maybe my outdated repair cd does not apply to the 05 06 xk8. Is there possibly something else that needs to be removed other than the 17m bolts? The slot on the rotor hat is closed and not open, is this how all the oem rotors came, or is that unique to 05-06? I am afraid if I keep pounding away at this thing I may damage the wheel bearing, is that a legitimate concern? Any help or advice from you guys would be greatly appreciated
Old Sep 13, 2013 | 04:00 PM
Brutal's Avatar
Theyre bad about rust build up at the hub to rotor in he center since the wheels hold water in there. Spray with penatrant and use a bigger hammer. I like to smack the face a couple times to break contact then go from the back
Old Sep 13, 2013 | 04:04 PM
ccfulton's Avatar
I also found that a 3/8 socket extension fits into the vent and makes a helpful handle for pulling on.
Old Sep 13, 2013 | 04:54 PM
waterloo's Avatar
Size:  69.7 KB the center is rusted so bad and in such a consistent pattern it actually fooled me into thinking it might be welded to the disk, im gonna wait and see if any of the pb oil can get through. I have already whacked it so much, is it possible to damage the wheel bearing if i keep it up? This thing is driving me crazy.
Old Sep 13, 2013 | 06:28 PM
I can't see a blanking plug there to access the handbrake shoe adjustor .........?
Mine is cross drilled Brembo but the standard disc should have the same arrangement.
Old Sep 13, 2013 | 07:22 PM
The Coupe's Avatar
Graham...
Our friend Waterloo is having trouble with the FRONT rotor, not the rear!
Old Sep 13, 2013 | 07:44 PM
Now why didn't I see that!
Old Sep 13, 2013 | 08:20 PM
waterloo's Avatar
Ok I have done the torch, liquid wrench, the 3/8th extensions for wiggling leverage (which was a great idea and does grip well) and hammered the hell out of this thing, but still no luck, I'm going to try to rig a bolt and nut from home depot to push it out, if that does not work I may need to bring a priest.
Old Sep 13, 2013 | 09:02 PM
ccfulton's Avatar
What are the "tab" looking things in the picture? I don't recall those being on my hubs when I changed the rotors.
Could they be biting into the hub and preventing the rotor from moving?
Old Sep 13, 2013 | 09:22 PM
Jag#4's Avatar
I was going to suggest the trick of putting the wheel back on with the lugs loose. Then you roll a few feet and stab the brakes. Do this a few times (short distance of course) and it may break free.
However, I didn't have any tabs on mine either. Good catch Charlie.
Old Sep 14, 2013 | 01:49 AM
waterloo's Avatar
I thought they were tabs too, that's why I was concerned the 06 was a different setup. But it turns out they are not tabs, the rust just formed in a really hard and consistent pattern. I'm going to look into that driving tip. I got the bolts to push one rotor and it has budged a tiny bit, but I have already snapped one bolt and chewed up the other. I'm going to have to fight these things until they come off completely since it appears all the metal has swelled considerably and there is no chance for a quick release by hammering them or popping them out with the bolts I got. How on earth could the metal swell this much on an 06 that has always been in a dry climate? The previous owner had painted the hats of the rotors, so I assumed that would help stop them from fusing, I guess he only painted the outsides. It looks I'm going to retire tonight defeated, but tomorrow is another day!
Old Sep 14, 2013 | 05:36 AM
gwagner's Avatar
Had a similar situation with my old Ford Explorer. I took my drill and a small bit and drilled a series of small holes through the disc around the perimeter of the hub. Eventually this removed enough material in the rusted area that allowed it to come free
Old Sep 14, 2013 | 05:51 AM
ccfulton's Avatar
How about a wire brush bit for a drill to clean the part of the hub it has to move across?
Also helpful when you do finally get it off to clean up all the surfaces.
Old Sep 14, 2013 | 07:19 AM
Lannyl81's Avatar
Wow....is this good to hear that my '06 was not the only one with this!
I used a drill mounted round wire brush to clean off the rust,
Lots of oil and time between rotor and hub,
Block of wood on the back side and hitting with a mini sledge,
Still would not come off.
Finally got the front rotors off by beating on the backside with a mini sledge and I do mean BEATING, destroyed both of them. Had to replace them...actually replaced all four rotors although the rears might have come off without destroying them, but I went straight to the BEATING the backside technique.
Got a set of cross drilled rotors, new set of brake pads.
Appears you will be doing the same.
Good luck.
Old Sep 14, 2013 | 11:39 AM
Bob OB's Avatar
Thumbs up Rotor removal
Got mine off last week at my indy. He used an ait hammer to loosen them up. Beating them into submission works!
Old Sep 14, 2013 | 02:37 PM
Brutal's Avatar
You did swipe with never seize before you put back on didnt you so you dont have to go through that again..
Old Sep 14, 2013 | 04:14 PM
ccfulton's Avatar
Where is the fun in that?
Old Sep 14, 2013 | 05:17 PM
plums's Avatar
Had one like this come in once.
The customer had very carefully dressed up his rotor hat with spray bomb enamel paint. On both sides. The paint baked to the hub.
They'll eventually come off, but it's going to be a struggle. In the case above, the mechanic resorted to a sledge on the backside of the tire. It still took a while.
If you put the tire back on with the lugs loosened by an eighth of an inch and raise the tire to just a couple of inches off the ground, you can sit in front of the tire and kick against the tire with both legs. Rotate and repeat.
BTW, a couple of those studs look like they might be on the edge of stripping.
Old Sep 15, 2013 | 09:54 PM
waterloo's Avatar
I got a chance to mount my second attack today. I followed the consensus here and beat them relentlessly with a sledge hammer. I hit them from behind the rotor outward, while turning them slowly. They were moving out so slowly that I had to mark them to make sure they were progressing. Strangely enough they never broke free even though I had already removed the rust in front of the rotor and lubed them. I had to bash them for what felt like forever until they were completely off. Obviously the rotors are now destroyed, I am very curious to see if the new rotors will need to be forced on. I believe the wheel design on this particular year is contributing to the problem and the rotors did indeed have some sort of paint or coating on them.
Anyhow, the moral of this story is- if your rotors look anything like mine, put the tires back on immediately and take it to a shop!
Old Sep 17, 2013 | 04:33 PM
Beav's Avatar
Electrolysis resulting from dissimilar metals (iron hubs and rotors, aluminum wheels) can make the job a PITA if the wheels have been in place for a long time. A little anti-seize compound brushed around the portion of the hub that projects through the rotor and into the wheel can help future dismantling.
