Help identifying this part (Part of A/C?)
Old Dec 16, 2023 | 04:09 PM
73MustangBill's Avatar
Default Help identifying this part (Part of A/C?)
I am in the process of reassembling my car after replacing all the front coolant hoses, radiator and condenser, alternator, A/C compressor, and belts. It's been a long-running project due to other commitments, so I'm just getting stuff bolted back in. I'm close to adding coolant, but decided to first check the A/C system to see if it holds a vacuum. It does not. I found this piece laying on the floor under about where the peanut connectors are on the right-hand side, under the air box location. It is aluminum, and the 1-1/8" wrench is there for scale. I'm wondering if maybe it was on the new condenser peanut fitting to keep one of the O-rings in place. Does anyone recognize this as something that goes in the system. or what I suspect it is?
Old Dec 17, 2023 | 09:02 AM
giandanielxk8's Avatar
I've never seen it before, but admittedly I haven't had to work with the A/C compressor. It looks like it might be a spacer or a gasket for the A/C lines?
Old Dec 17, 2023 | 09:41 AM
motorcarman's Avatar
Looks like a BLANKING PLUG holder for a rubber insert to keep lubricant in a compressor or debris OUT.
Old Dec 21, 2023 | 02:37 AM
Pistnbroke's Avatar
The small hole goes over a raised pin and the larger one is where a bolt comes through . To stop rotation
wydopnthrtl
Jun 14, 2020 06:17 PM
smgdata
Jul 4, 2019 02:08 AM
diesellee
May 20, 2017 05:08 PM
Jag-o-nomic
Dec 4, 2016 10:12 AM
YYC guy
Jun 8, 2012 01:31 PM
