Help! Low Coolant Indicator
Old Oct 6, 2009 | 07:11 PM
sparkenzap's Avatar
1. Quite simply, you, or somebody, must decide if the coolant is low when the light comes on.
2. It is highly unlikely that a bad water pump causes the light, except if the pump is leaking and lowering the level.
By the way, be aware that there is an "overflow tank" that the coolant can move into, then be sucked back to the tank. That can confound your diagnostics from #1.
Old Oct 6, 2009 | 08:03 PM
Thermo's Avatar
Veteran: Navy
Mike, here is a quick check that you can do. Locate the low coolant switch on the side of the coolant reservoir. Unplug the 2 wire plug associated with it. You will note a orange/green wire and a blue/pink wire. By disconnecting the plug, you should force the low coolant light out. If the light does not go out, insert a small piece of wire between the two pins. By doing these two checks, this will confirm if your low coolant light issue is a switch related problem (easy fix, replace the low coolant switch) or if you have a bigger wiring issue. With the plug disconnected, the orange/green wire should have 12 VDC on it (roughly). When the low coolant switch is activated, it grounds this voltage, tripping the computer to light the light.
As for the fan running after the car is turned off, I doubt this is tied with the low coolant light problem. But, it may be a good time to do a flush of the coolant system since if you do have to replace the switch, you will need to drain the coolant system atleast part way. Doing a good flush on the system may clear a possible blockage in the radiator which is causing the car to run a little bit warmer than normal.
Hope this helps.
Wahooesprit
Dec 23, 2019 02:01 PM
Tipptone
Sep 16, 2015 07:39 AM
Johnken
Sep 15, 2015 05:46 PM
1100me
Sep 7, 2015 06:26 AM
Mosers63
Sep 6, 2015 02:53 PM
