Help, lower thermostat housing screw is stuck. RESOLVED
Old Aug 12, 2018 | 12:22 PM
giandanielxk8's Avatar
Default Help, lower thermostat housing screw is stuck. RESOLVED
Can’t get the lower thermostat housing screw out. I can’t even get it to budge. Unlike the ones in the guide that’s circulating around the form, mine has Torx screws, which makes this job super uncomfortable. Any ideas?
The guide: http://matt.zenfolio.com/xk-coolant-...tat---v1-1.pdf shows 10 mm screws.
Last edited by GGG; Aug 12, 2018 at 05:39 PM. Reason: Add "RESOLVED" to thread title
Old Aug 12, 2018 | 12:47 PM
Problem solved. While I was eating my step dad went at it with a hammer and a flathead and got it out.
I’m going to buy the correct 10 mm screws.
Old Aug 12, 2018 | 05:38 PM
Originally Posted by giandanielxk8
..... mine has Torx screws, which makes this job super uncomfortable. Any ideas?
Someone has been there before. Torx should be easier to remove than OE standard bolts.
Ideas? Hide your father's hammer before he attacks any of the more brittle parts on the car.
Old Aug 12, 2018 | 08:22 PM
Hahaha, in fact they are not any easier. However, from the condition of the bolts used, I would say it was quite a long time ago. The lower bolt is in an awkward position that makes it impossible to get the torx bit head on a screwdriver. A ratcheting wrench with the appropriate torx adapter is too bulky to fit in that space. The torx bolt in question was already stripped when he got it out. Luckily he's a very mechanically inclined guy and managed not to damage anything. However, a 10 mm wrench, or 10 mm ratchet is slim enough to provide ample space to work on. I bought 4 screws to have 1 as a spare. I changed the thermostat ($14.99) and put it all back together. Problem solved.
I agree, someone definitely has swapped the thermostat on this car before. As I have gotten to know this car, I think I can say that the previous owner, before my late father, definitely kept up with the maintenance on it. So far I have only had minor issues (knock on wood).
SuperTrav
Nov 24, 2015 07:31 PM
jaggirl75
Nov 4, 2015 08:30 PM
jagxk82005seneca
Jan 12, 2015 08:37 PM
akubeta
Sep 26, 2013 06:38 PM
djpxk8
Sep 30, 2011 09:59 PM
