Help ! - Manual close of top
Old Jul 16, 2010 | 02:42 PM
vajaguarxk8's Avatar
Default Help ! - Manual close of top
My top isn't fully closing. (I was driving a little too fast and it stopped duing the close sequence and won't restart the open or close sequence).
How do I get that plastic plug off that covers the area where I insert the allen wrench? I'm trying w/ a tiny flat screwdriver and don't want to break it.
Will the rear windows close after I manually close the top?
Old Jul 16, 2010 | 02:55 PM
Gus's Avatar
Gus
Yes the windows should close after the top is latched. To remove that plug you just need to use a larger screwdriver. Go to my page and you will see info on a how to http://www.gusglikas.com/AutoRepairH...lOperation.htm Let us know if you need additional help. Do you know why the top stopped closing??
Old Jul 16, 2010 | 03:10 PM
SeismicGuy's Avatar
A small coin will also help to pry the cap off.
Doug
Old Jul 18, 2010 | 03:48 PM
Issue solved. I was trying to remove the "cap" under the homelink panel. I totally missed the "proper" hole that I was looking for. After gouging out the wrong hole, I now need to find some way to repair the damage I caused.
Old Jul 18, 2010 | 05:44 PM
Gus's Avatar
Gus
You can go to my page http://www.gusglikas.com/autorepair.htm and see all the info I have on the roof operation and hose evaluation http://www.gusglikas.com/AutoRepairH...lOperation.htm and info on hose replacement if you elect to do it yourself http://www.gusglikas.com/RoofHoseReplacement.htm I hope this helps
99xk8guy
Sep 29, 2025 10:51 PM
aholbro1
Dec 29, 2024 06:46 PM
99xk8guy
May 28, 2024 09:36 PM
Sambo21
Nov 19, 2015 03:55 PM
1100me
Sep 7, 2015 06:26 AM
