Help, Metal to Metal or Rubber Noise - RESOLVED
Old Oct 26, 2012 | 04:49 PM
yyk's Avatar
yyk
Question Help, Metal to Metal or Rubber Noise - RESOLVED
From rear area going over certain bumps, manhole blocks at speed. You can hear it when you got the windows down. Also at times when you put the car into drive on a flat surface when parked. It sounds like a creak or loud cricket, but not as loud putting it into gear.
Mechanic has even ridden in trunk and he thinks it seems to be coming from left rear, but he can't pinpoint the sucker. He's checked gas cover assmbly, purge control valve, tank, cover, exhaust, shocks, radio, taillights, decklid, nothing. We're stumped.
2000 XKR
123k ml
Last edited by GGG; Nov 8, 2012 at 05:43 PM. Reason: Add 'RESOLVED' to thread title
Old Oct 30, 2012 | 07:29 AM
yyk's Avatar
yyk
Default Aging model year
As a self-help methodology, since these cars are aging, I am replacing the upper shock rear bushes, and have the shocks tested. Are there any spring-end bushings on the rears?
The model year has non-CATS suspension.
Mike,
2000
XKR
Phoenix Red
Old Oct 30, 2012 | 09:07 AM
Now you've eliminated the rear shocks as a possible source of the 'metal or rubber' noise, you should check the Rear Subframe Bushes (circled in red):
These are pressed into the rear subframe and can cause all kinds of odd creaks and groans when they start to break up:
Attached Thumbnails Help, Metal to Metal or Rubber Noise - RESOLVED-rear-subframe.jpg   Help, Metal to Metal or Rubber Noise - RESOLVED-xk8-rear-suspension.jpg
Old Oct 30, 2012 | 09:27 AM
Paul Pavlik's Avatar
Mike,
2000
XKR
Phoenix Red
AFAIK, all U.S. Spec XKRs have CATS as Standard Equipment.
Old Oct 30, 2012 | 11:07 PM
yyk's Avatar
yyk
Which part number is that 13 "Monostrut" or on that goes on top of it? And how hard would it be to replace that once you remove the spring?
Thanks Paul.
Old Oct 31, 2012 | 06:33 AM
yyk's Avatar
yyk
Default CATS on XKR number of wires
Paul,
Your quote AFAIK, all U.S. Spec XKRs have CATS as Standard Equipment.
In another post you said there is a wire going into the shock tower under the hood, how many wires on each side should there be? Will the black rubber boot still be near it?
Mike
Old Oct 31, 2012 | 08:00 AM
ccfulton's Avatar
Paul,
Mike
It is a simple solenoid that changes the valving so only two wires to each shock.
Old Oct 31, 2012 | 08:43 PM
yyk's Avatar
yyk
Paul,
Appreciate your help, in the pic with the circle in red. With the sway bar carrier-11, would the part in that picture near extreme left 12 and 13, would those bolts carry any bushings? I can't tell.
Mike
And how do you 'lectronically "thank" a responder who answers a question in a post Paul?
Old Oct 31, 2012 | 08:47 PM
yyk's Avatar
yyk
Figured it out the Thanks. Graham.
Mike.
Old Nov 1, 2012 | 03:12 AM
Mike,
An alternative to OE Jaguar suspension bushes is Powerflex. Whilst you may not wish to use these, their parts diagram for the XK8 is useful to show the location and identity of the bushes:
Powerflex is a popular upgrade with members. Advantage is they last longer. Disadvantage is a slightly harsher ride.
Attached Thumbnails Help, Metal to Metal or Rubber Noise - RESOLVED-powerflex.jpg
Old Nov 8, 2012 | 05:36 PM
yyk's Avatar
yyk
Replaced pair of innder rear sway bar bushes, the pair of powerflex pressed 7's (main body mounting bushing), and the pair of upper strut mountings and added the rubber pad insulators above each strut to hide road noise and the squeak is gone.
The original bushings were in pretty bad shape. The fronts had been replaced already.
V/r
Mike
Old Nov 8, 2012 | 05:42 PM
Mike,
Great result.
Thanks for posting about the successful outcome and replacement part details.
I've added 'RESOLVED' to your thread title to help others in future searching for an answer to the same issue.
Razor
Aug 28, 2019 08:34 PM
GordoCatCar
Jan 2, 2017 01:10 PM
Poet
Oct 6, 2015 09:40 PM
Ipc838
Sep 13, 2015 03:27 PM
raulan
Sep 10, 2015 12:43 PM
