help with ,no spark hot
Old Jun 30, 2015 | 12:13 AM
xk8don's Avatar
Default help with ,no spark hot
Hi guys ,I'm new to the forums as I recently bought a 1997 XK8 with problems .
first the transmission needed to be repaired. had a broken forward drum . replaced the drum , clutches ,steels . and installed a transgo pressure regulator valve to FIX the problem of spiking high mainline pressure. Trans seems ok.
I bought the car knowing it had trans problem , now I'm learning the problems the previous owner DIDN'T tell me about !!
After the car runs and is driven for about 20 minutes and get up to temp , when I shut the car off it will not restart, until the car cools down ,30 minutes or so . It always starts after it sits.
I've checked the coil packs and there's no spark when it won't run. once it refires of course there's spark which I verified just to prove to myself I was testing it properly.
hoping maybe some of you have seen this kind of thing before . I'm getting a crank sensor tomorrow to try that. Has some other problems , but I'll try to deal with them one at a time.
Thanks Don
Old Jun 30, 2015 | 01:25 AM
Welcome to the forum Don,
I've moved your thread from General Tech Help to XK8/XKR forum. This is the place to post tech questions about your model.
Old Jun 30, 2015 | 03:40 AM
WhiteXKR's Avatar
Get an OBDII reader and read the fault codes, then post them here. Guessing will get very expensive, very quickly.
Old Jun 30, 2015 | 06:46 AM
marvin.d.miller's Avatar
...OR...it could be a simple fix. I've fixed my XK8 a few times with little to no money.
Why must people on this forum discourage new owners...
Old Jun 30, 2015 | 07:07 AM
aode06's Avatar
my 97 did that, it was the crank sensor/no codes, splice the new one with to the old units wiring, you will never get to the connection, thanks to a wise **** engineer.
Old Jun 30, 2015 | 09:46 AM
xk8don's Avatar
I have a snap on scanner ,how ever I can only get in under globel so its limited.
I understand how exspensive car and boats can get,, If you let them. trans mission repair only cost me about $500.
thanks aode06 that's were I'm going first
Old Jun 30, 2015 | 10:22 AM
WhiteXKR's Avatar
Why is recommending getting an OBDII scanner which you can buy for under $10 (see obdii bluetooth | eBay) that will give you important clues as to your problems, saving time, money and aggravation discouraging?
Old Jun 30, 2015 | 12:23 PM
Talking
The OBDII isn't the focus of my statement, it's the latter half...
Old Jun 30, 2015 | 01:40 PM
WhiteXKR's Avatar
You are completing misinterpreting my intent out of the context of the thread.
Don, the original poster said he had several problems. He made no mention of reading the codes. I was encouraging him to read the codes and approach the problems from a position of knowledge.
Sure you can get lucky at guessing. Depending on your experience, you might be able to intuit the cause of certain problems. But spending a few bucks on an OBDII scanner can save a lot of heartache and expense...that was my point in the context of this thread.
Old Jun 30, 2015 | 02:35 PM
xk8don's Avatar
white xkr ,I thank you for your help. however as I mentioned ,I have a snap on scanner. I didn't mention any codes because I haven't found any. I would never just guess aimlessly. not all problems set DTC's. what's the code for a failed computer? as aode06 mentioned could be crank sensor /no code . I do like that blue 'tooth unit though .
Old Jun 30, 2015 | 02:43 PM
xk8don's Avatar
I am finding that if I cycle the key the computer does not seem to store any codes in memory like other cars. seems I am going to have to have the scanner with me when the problem occurs and scan it with out turning the key off
Old Jul 1, 2015 | 04:12 AM
aode06's Avatar
BAD ECM-SEND TO ASI FOR A BENCH TEST OR
rotary switch on transmission,failed,mis-adjusted,installed backwards
crank sensor, bottom front/lower/face of transmission. Damaged, burt up, intermittent operation when hot/no operation when hot.
BAD EARTH GROUND OR NO EARTH GROUND STRAP from transmission to passenger side frame-transmission installer error.
Spazzzzzzzzzy
XJ40 ( XJ81 )
Oct 5, 2015 04:05 PM
inactualis
Oct 2, 2015 11:13 AM
hoodun
Oct 2, 2015 02:06 AM
Vector
US Lower Atlantic
Sep 28, 2015 11:08 AM
