p0105
Old Jul 1, 2015 | 04:22 AM
dodgerjames's Avatar
Default p0105
have a p0105 code after engine light,any ideas please
Old Jul 1, 2015 | 04:58 AM
jamdmyers's Avatar
from google
P0105 Jaguar Description
The Manifold Absolute Pressure (MAP) sensor provides instantaneous manifold pressure information to the engine's Engine Control Module (ECM). The data is used to calculate air density and determine the engine's air mass flow rate, which in turn determines the required fuel metering for optimum combustion. A fuel-injected engine may alternately use a Mass Air Flow (MAF) sensor to detect the intake airflow. In some vehicles the absolute pressure sensor is built into ECM.
I would start by cleaning the MAFs, then u might check the MAP
PaulB
Jul 12, 2016 05:27 PM
JLRGaz
Jun 24, 2015 08:20 PM
vwguy777
Apr 18, 2012 04:02 AM
Vinny37
Apr 11, 2010 01:14 PM
Jag4.0
Jul 14, 2008 03:38 PM
