Help!! space between the hood & front bumper
Old May 1, 2010 | 01:41 AM
mrmagnum's Avatar
Default Help!! space between the hood & front bumper
Need Help! just got my used jag xk8 & I've noticed a rather wide
space between the front bumper & the hood. I was told it was normal
for xk8s but I knew it wasn't. Does anybody here has a similar
situation as mine?
Thanks for any help!
Old May 1, 2010 | 06:07 AM
test point's Avatar
JTIS is available as a free down load on this forum:
https://www.jaguarforums.com/forum/s...ead.php?t=9933
My clearance is about a 1/4".
Welcome aboard!
Old May 2, 2010 | 01:56 AM
mrmagnum's Avatar
Hi XK8INMD! super thanks for your quick reply & for the info!
my email ad is williamjessemagnum@yahoo.com
Glad to be here! Thanks again!
Old May 2, 2010 | 01:57 AM
mrmagnum's Avatar
Hi Testpoint! super thanks for your quick reply & for the info!
Very much glad to be here! This is a great site with very helpful people.
Thanks again!
Old May 2, 2010 | 10:02 PM
GordoCatCar's Avatar
Be more specific. How much space? A picture of the gap would be most helpful.
I just had my front fascia off while fixing an accident repair. There are a number of ways to tighten up gaps between the fascia/fender and fascia/hood.
Old May 3, 2010 | 10:43 AM
mrmagnum's Avatar
Gordocatcar, i added 2 photos from a link thru my flickr photos page on my first post above but it didnt show up.. anyway, here's the link.
http://www.flickr.com/photos/1105582...26216/sizes/o/
the gap is around 0.4-0.5cm wide
Old May 3, 2010 | 11:02 AM
That is definitely a large gap. The front fascia can be raised a little by the use of shim washers under the front edge of the fascia. Keep in mind there needs to be some gap in order to allow the front edge of the hood to dip while raising the hood.
If you look on your JTIS, you'll also note there are three (3) bolts on each side attaching the fascia to the lower fender edge. You may loosen these to facilitate a better fit.
I would be cautious about religning the hood on its hinges because of issues with the locking mechanisms at each upper hood corner.
Pulling the front fascia is not a difficult task. You can access the front bolts and three (3) push pins by raising the hood to its "service position" which is nearly 90 degrees vertical. Do this by removing the support pistons and inserting one each bolt on either side of the front hinge location. It looks precarious, but is actuall quite stable if you are not outdoors [in the wind].
Old May 4, 2010 | 09:45 AM
mrmagnum's Avatar
Thanks gordocatcar for the advices. il try just that!
H20boy
Dec 24, 2024 03:23 PM
Daim
Nov 28, 2016 09:28 AM
mrplow58
Sep 9, 2015 11:27 AM
prettydaim
Sep 4, 2015 09:13 AM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
