Help!! What has gone on my engine?
Old Feb 8, 2014 | 08:09 AM
Jon89's Avatar
FYI - The 2005 S-Types had a recall to replace leaking gas tanks. The leak occurred where the fuel filler tube joined the tank. Symptoms included gas spilling onto the ground during fill-ups at the gas pump. My S-Type had its gas tank replaced under this recall prior to us purchasing it....
Never heard of this issue on an XK8, but I thought you might want to know....
Old Feb 8, 2014 | 01:49 PM
Bad Cattitude's Avatar
Old Feb 8, 2014 | 06:42 PM
philhef's Avatar
Originally Posted by WhiteXKR
Is the fuel visibly leaking out?
Oh yes. I'm sure it's right where the line exits the trunk. There's no fuel in the boot or smell, so it's under the car. The line.
Old Feb 8, 2014 | 07:53 PM
Gus's Avatar
Gus
The leaking fuel is a serious issue, have you had the fuel pump replaced recently? I am attaching a link on the procedure to replace the fuel pump and on the last page #5 toy can see the fuel lines and where they go into the tank. I hope it helps.
Link http://www.jagrepair.com/images/Auto...eplacement.pdf
Once the fuel leak is corrected I would have your battery tested Jaguar electrical system is critical and does not take voltage fluctuations lightly.
I am also going to attach a procedure on how I clean a Throttle Body and it might help. It not only cleans the TB all the other stuff to the plugs. I should also mention that I use BG44K as a fuel additive.
I hope this helps.
D.K
Dec 10, 2023 02:05 AM
cissdm
May 3, 2016 06:02 AM
OkieTim
Sep 8, 2015 04:48 PM
MrMellor
Sep 7, 2015 10:22 AM
OkieTim
Sep 2, 2015 12:48 PM
