Here's something interesting...
Old Nov 20, 2014 | 07:10 AM
marvin.d.miller's Avatar
Talking Here's something interesting...
I don't know if this really means anything, but I figured I'd mention it.
We all know the standard daily/weekly "Stability/traction control failure" message, and the fact that the owners manual says the vehicle can be driven with this message. Also, we all know there's no urgent message in the manual instructing you to get your butt to the mechanic as soon as possible. So, we all drive, press the "clear" button until we decide to address the problem.
NOW, the reason for this post...
Here in the Pacific Northwest (Washington/united states) we just went through a cold snap that lasted 3 1/2 weeks. The temperatures were hovering 25/30 degrees (F). The day before the cold snap, error message. However, for the full duration of the cold snap, all 3 1/2 weeks, no error message. The day the temps rose to around 40 degrees, the error message returned.
I know the issue is caused by the two tiny soldering points, but what does the cold have to do with it?
Coincidence or a clue to our little issue with the stability/traction control failure messages.....hmmm...
Old Nov 20, 2014 | 07:29 AM
Dennis07's Avatar
Are you sure the error is coming from the ABS module and not, say, an intermittent connection in the front sensor wiring?
Both are pretty common.
Old Nov 20, 2014 | 07:32 AM
Poppyboy's Avatar
Good question, for which there's probably no answer. I did the ABS module soldering fix (along with cleaning the wheel sensors) about a month ago. Temps were in the 50s/60s. The messages disappeared immediately. They stayed away for a week or so, then reappeared. I had the car in the shop for new front bushings. After that, with temps in the 40s and 50s, the messages disappeared. Then, and day or so later, they reappeared. The temps then plunged from the 50s to 20s. The messages disappeared for several days, but then reappeared. Someone once posted that it could take many miles before the messages stay away after the fixes are done. I really don't care anymore. It's stored outside under cover and tarp, hooked up to the CTEK until March or so...
Old Nov 20, 2014 | 07:40 AM
Dennis07's Avatar
With a little detective work, it's usually possible to tell one from the other ... or at least to make an educated guess.
If the error is not there on startup, but pops up after some steering inputs or suspension travel, that suggests the front sensor wiring. Even without jacking the car, you can clean and re-seat the front sensor connectors to see if that clears the fault ... pretty conclusive if it does (even temporarily). That front sensor wiring can be rearranged to take stress off the connectors ... I've gotten a long term fix on two XK8s that way.
The error message will be gone on next engine start if the fault is gone. The yellow abs icon might stay on for a while longer though.
Old Nov 21, 2014 | 12:55 PM
XxSlowpokexX's Avatar
I just wanted to chime in. Sometimes I think I know too much. And sometimes I feel it's hard to find the right information here. But I had an intermittent ABS issue. Checked the ABS module, cleaned the wheel sensors....And well, finally checked it with a code reader. Said left front sensor.....Changed it....Same issue...It was the line. I don't know how or why. But the line itself was bad. My advice. Check which sensor. Swap out with another. If same sensor location comes up in the code its likely the line. Or you can confuse yourself and start checking the ohms of each wire and do the wiggle test. I personally like swapping out the sensor with another wheel and then retesting after a drive. GOOD LUCK!
Old Nov 21, 2014 | 03:13 PM
sheddist's Avatar
Similar issue here. Intermittent ABS light then became permanent. When the intermittent fault started I checked the sensor resistances from the modle connector and allw as well. Unfortunately this was misleading. Whne the light was on permanently, I bit the bullet and bought the needed to read the ABS codes. This showed a front RH open circuit. Sensor resistance was OK, took the link lead off and this was OK, until refitted. Turned out that this part, replaced with a new one in 2012, had a faulty crimp and was making intermittent contact at the sensor end. Replaced the connector with a new one including crimped and soldered terminals and heat shrink strain relief.
In anticipation of future fun, I have a stock of connectors for both ends and some silicone test lead cable.
Cybersib
Non-Jaguar Vehicles
Apr 20, 2015 08:44 AM
jwmarkee
Mar 25, 2013 07:58 PM
AdamNL
Feb 25, 2013 12:03 PM
55chevy
Jan 24, 2011 11:12 AM
Jaggyx
Jun 24, 2010 09:21 AM
