HID levelling sensor
Hi,
While working under my car recently I have kind of fallen down the rabbit hole with new jobs to do. One of which is the headlight levelling sensor... mine is missing from the front suspension and the connector is simply dangling inside the wheel arch.
Weirdly this does not appear to chuck up any codes or warnings.
Seems like a pretty simple job to put one in anyway but I'm not entirely sure what parts I might be missing aside from the sensor itself. The workshop manual does not show anything comprehensive.
If anyone happens to be working on their car with the front wheels off could you take a quick snap for me so i can see how the whole lot goes together?
Thanks,
Owen
Thanks,
Owen
Thank you so much for this!
The complete assembly is missing from mine. No brackets or anything so seems I have quite a bit to find. You can buy the sensor itself easy enough but I think the brackets will be a scrap yard job.
I could see the holes on the vertical beam so presumed the sensor attached there but couldn't work out where the other end of the arm attached.
Your suspension looks super clean! Put me to shame!
I thought this would be a quick job to tick off my list but looking online there is no sign of the brackets readily available. Sensors yes but everything else is going to be a headache 🤦♂️
You can try to make your own bracket? It doesn't look like a complex shape.
Just depends how much flexibility there is in the calibration to compensate for the imperfection of the brackets.
Both are listed here:
https://www.sngbarratt.com/English/#/uk/FindParts/Families/XK8%20~2F%20XKR/11/XK8%20~2F%20XKR%20-%20To%202006/47/LIGHTING%20-%20EXTERIOR~2FINTERIOR/13599/assembly/10667
