hood
Old Jun 6, 2017 | 07:37 PM
JWheaton10's Avatar
Default hood
I am having trouble opening the hood on my wife's 2003XK8 convertible, the passenger side hood release does not want to release.
Any ideas?
Thank you,
John
Old Jun 6, 2017 | 08:32 PM
motorcarman's Avatar
Use the HEX key in the boot near the convertible hood pump after turning the hydraulic release knob.
The key is inserted into the top latch behind the interior plug and turned to release the mechanical latch/lock rods from the outer latches.
There is a danger of bending the top frame if the rear section is not pressed in as the top is lowered. The frame is unlocked by means of pulling the frame hinge where the lift rams are attached.
If you are referring to the bonnet then please rephrase the question.
bob
Old Jun 6, 2017 | 09:00 PM
omgimali's Avatar
yea bob i think he is referring to the Bonnet
Old Jun 6, 2017 | 11:11 PM
Jandreu's Avatar
Yelp, OP is in Michigan so he speaks US English.
Old Jun 7, 2017 | 09:55 AM
Roger_B's Avatar
I had difficulty releasing my hood, so I pulled so hard that the snaps tore out of the jacket. Now I just wear a bonnet.
swingwing
Aug 7, 2020 07:54 AM
bobsalmon
Dec 20, 2016 04:57 AM
Bigg Will
Dec 8, 2016 03:14 PM
BCJAG
XF (X260)
Nov 24, 2016 02:08 PM
