How do I adjust toe?
Old Feb 10, 2016 | 03:39 AM
chris.schneider's Avatar
Default How do I adjust toe?
This might be a stupid question, but I want to be sure before I mess something up.
I replaced the track rod ends. Measured the track before I did that, and I’m confident that it will be the same with the new rod ends.
However in case I need to adjust track / toe – how is that done? Did not find any description in JTIS.
The tie rod ends are secured with a counter-nut, so I assume I can turn the tie rod like in any other vehicle, just need to undo the gaiter. Is that a correct assumption, or does Jaguar expect me to undo the tie rod end and turn it for adjustment?
Chris
Old Feb 10, 2016 | 04:16 AM
kingfishgrapejam's Avatar
Chris
You're correct just loosen the jamb nut and turn the rod. Tight the jamb when done. You can probably get if close by string or eye but take it to a machine to save your tires in the long run.
chaby88
Jul 9, 2021 06:00 PM
PVK
Feb 11, 2016 02:21 PM
sg18438
Feb 10, 2016 12:54 PM
hemlock
F-Pace (X761) / C-X17
Feb 9, 2016 07:41 PM
Jaguar Forums Editor
Jaguar Press release
Feb 9, 2016 09:48 AM
