How much play should throttle cable have
Old Apr 13, 2011 | 06:40 PM
cheaperts's Avatar
Cool How much play should throttle cable have
Should there be any play in the throttle cable, Im wondering if I should /can adjust out the slack, heres a video showing how much play it has
Jaguar :: throttlecable.mp4 video by cheaperts - Photobucket
Old Apr 13, 2011 | 07:07 PM
test point's Avatar
Subject of recent discussions.
https://www.jaguarforums.com/forum/x...estored-38663/
Old Apr 13, 2011 | 07:08 PM
SeismicGuy's Avatar
The JTIS procedure to adjust the throttle cable (for the latter year models) shows that there is a special "tool" used during the adjustment that results in providing some slack in the cable. If you do not have this tool (who does?) I think that you can just guesstimate that some slight slack needs to be there. The ultimate check is to have someone slowly floor the pedal while you watch the throttle body butterfly and see that it is opening fully.
Doug
Old Apr 13, 2011 | 07:11 PM
hlgeorge's Avatar
cheaperts, Looks like the cable has very little play in it. You need some play or your rpms will go up at idle.
Gus
Oct 15, 2019 12:29 PM
xjrjag
Oct 12, 2015 03:16 PM
thedugger1
Sep 26, 2015 10:27 PM
Woznaldo
Sep 26, 2015 11:02 AM
Johnken
Sep 22, 2015 03:53 PM
