How often do you wash your soft top?
Old May 16, 2015 | 11:57 AM
RaceDiagnostics's Avatar
Default How often do you wash your soft top?
It took a lot of effort and a whole range of cleaning products to get the top clean on Kim's car, and since doing this last year I have washed the top pretty much weekly when I wash the car.
I just give it a gently wipe over with the same car wash fluid/water mix I use to wash the car, and a gentle hose down afterwards.
What do you all do?
Old May 16, 2015 | 12:34 PM
Jag#4's Avatar
Pretty much the same for me. I do use a gentle brush on it about once a month during the wash to loosen the dirt and such.
Once a year treatment with 303 top care.
Old May 16, 2015 | 01:00 PM
giandanielxk8's Avatar
Pretty much the same as you guys. I wash it as I do the rest of the car. I treat it as if it were a coupe. Every 3 or 4 months I use the 303.
I do however scrub it vigorously with a soft microfiber cloth each time I wash it because of those damn cats.
Old May 16, 2015 | 03:38 PM
Jon89's Avatar
I scrub it down with old cotton diapers every time I wash the car. It gets a 16-ounce treatment of 303 once per year, usually in May. Haven't treated it this year but will do so the next time I wash the car....
Old May 16, 2015 | 04:25 PM
test point's Avatar
I hose it off with a hard spray every time I wash it . . . no soap, no scrubbing. RaggTopp once a year.
Bought 303 to give it a try next time I do it.
Old May 16, 2015 | 04:30 PM
I use Meguiar's Convertible Top Cleaner with a soft bristle brush each time I wash the car. I just treated it with 303 last week.
Old May 16, 2015 | 06:06 PM
I've never cleaned mine except a hose off when I wash it, those that have read the other thread will know how often that is, I do have a package of 303 cleaner and treatment at home so it will have a treat next week.
Old May 17, 2015 | 06:10 AM
Hare's Avatar
I use the protective spray from Glymol. Really beads the water so just a rinse is needed for cleaning.
Old May 17, 2015 | 07:08 AM
noterman's Avatar
Want to make sure I found the right product. Is it called 303 Protectant? White bottle, 16oz for around $18.00. Thanks
Old May 17, 2015 | 10:58 AM
MRomanik's Avatar
Veteran: Air Force
My bottle says Fabric Guard
Old May 17, 2015 | 11:25 AM
Jon89's Avatar
That's it. 303 High-Tech Fabric Guard Water Repellent....
I buy the 32-ounce bottle and get a bit of a price break. I use half the bottle for each annual treatment, so one bottle lasts me two years....
Old May 17, 2015 | 07:51 PM
stetson1's Avatar
Hey Steve, was curious, did you ever resolve your 'water' issue? hope all is well,
frank
Old May 20, 2015 | 09:12 PM
DAN L's Avatar
Default cleaning top
hi i was going to the ragtop kit to do mine it has a few stains in it .is the 303 a better prouct?thanks dan
Old May 21, 2015 | 06:15 AM
worrasf's Avatar
As little as possible.
I'm a bit OCD with my softtop care. It gets waterproofed every spring and autumn with Renovo and a recolour - again with Renovo every spring.
I use a Cabriolet cover (Jaguar XK8/XKR Car Hood Soft Top Cover Half Cover Protection 1996-2006 | eBay) every night as well as lightweight outdoor cover in spring/summer and a heavyweight one in winter when it's off the road for 6-months.
I have to be picky like this as the UK weather is so foul (well it is in Yorkshire anyway) and I have to keep it outside parked under trees when at home.
While a bit time consuming (5-mins in the morning to remove covers) - the soft top is virtually as new.
Steve
Old May 21, 2015 | 07:03 AM
frank
Frank - no - still leaks but we have not had much rain the past month and I was able to clean out enough of the garage that I can park inside now rather than leaving out in the elements. I am considering replacing all the seals along the top since the car is 15 years old and the SC heat/humidity are killer.
Steve
Old May 21, 2015 | 01:58 PM
MediaBobNY's Avatar
RaggTopp horse-hair brush every time I wash the car; let air dry. RaggTopp protectant twice a year.
Old May 21, 2015 | 07:24 PM
noterman's Avatar
303 makes a product called 303 Fabric Guard, and also 303 High Tech Fabric Guard. They are priced differently. Which one do you suggest.
Old May 24, 2015 | 06:39 AM
jamdmyers's Avatar
Larry Just uploaded a segment on Top cleaning, maybe worth a look he knows what he's talking about when it comes to detailing.
Fortunately we have glass as the rear window.
Old May 24, 2015 | 11:09 AM
worrasf's Avatar
As per my post 14 get one of these: Jaguar XK8/XKR Car Hood Soft Top Cover Half Cover Protection 1996-2006 | eBay
Whatever method you choose to clean/restore your softtop you will have to do it all over again if it's not protected from the elements (esp UV) when not being driven
Steve
Old May 24, 2015 | 04:22 PM
Gus's Avatar
Gus
I wash the roof every time I wash the car.
