How to remove glass lens from the front headlight assembly AKA headlight lens?
Old Oct 1, 2012 | 09:07 PM
jagosaurus's Avatar
Question How to remove glass lens from the front headlight assembly AKA headlight lens?
I mean only the glass plate, it's glued to the rest of the assembly and I've already chipped it a little
I tried to search for it in JITS, but no mention, tried a heat gun, but not sure it helped much. HELP!
Old Oct 1, 2012 | 11:11 PM
jagosaurus's Avatar
Ok, I managed to do it, but being reckless I damaged it:
The best way I found was to use a thin chisel, and a plastic scraper, get them in between the glass and the plastic body and use them as levers to slowly make the glue release. Much like you would use plastic levers to remove a tire from a bicycle. Be very careful with using small or metal levers, as the glass can chip or crack. DON'T USE A DREMEL AROUND THE EDGES, like I tried.
Old Oct 3, 2012 | 01:36 AM
XKRacer's Avatar
Shame I did not get on here earlier..... put it in your kitchen oven at 120C and wait about 30 minutes checking after about 20 mins and it pulls straight off. never use screw drivers or chisels! Otherwise you will chip/crack the glass!
Old Oct 3, 2012 | 01:39 AM
jagosaurus's Avatar
Next time.. at least the damage is only cosmetic.
Old Oct 3, 2012 | 01:51 AM
jagosaurus's Avatar
Found an entire headlight in decent shape for $119 on Ebay, glass in perfect condition, so hopefully i can sell the back piece to make my money back
dsnyder586
Dec 29, 2024 07:39 PM
Skeeter
Sep 17, 2015 08:15 PM
edtexas
Sep 5, 2015 10:49 AM
laserguy
Sep 3, 2015 02:02 PM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
