How tight should the shock nut and mount nuts be?
Old Jul 24, 2016 | 06:45 AM
Anthony8858's Avatar
Default How tight should the shock nut and mount nuts be?
i had all shocks and mounts replaced yesterday on my 98 xk8.
Coming home in the quiet of the night, i heard some knocking seemingly coming from driver's side / upper.
This morning I took the plastic caps off the nuts that secure the mount and put a open end wrench to them.
On 2 of them, I was able to get almost a full turn.
Also on the shock itself, I was able to put a ratchet and give it a 1/2 turn.
Should I have been able to turn that at all?
Or should they be super tight?
Old Jul 24, 2016 | 08:26 AM
they should not be loose - below torques are from workshop manual which is available for free download here - check the DIY & How To threads
Torques
CAUTION:
Replacement of nuts and bolts: Various thread-locking devices are used on nuts and bolts throughout the
vehicle. These devices restrict the number of times a nut or bolt can be used. See section <<100-00>> for
information.
Component Nm
Nut - ball joint-upper 60-80
Nut - ball joint-lower 60-80
Bolt - brake disc shield 9-11
Bolt - crossbeam front mounting bracket to body 77-103
Bolt - crossbeam rear mounting to body 77-103
Bolt - crossbeam to rear mounting 26-34
Bolt - crossbeam to engine mounting 34-46
Nut - hub rotor nut 270-330
Nut - shock absorber lower pivot 60-80
Nut - shock absorber upper stud (non-adaptive damping) 30-40
Nut - shock absorber upper stud (adaptive damping) 16-18
Nut - spring and shock absorber upper-mounting to body 26-34
Bolt - stabilizer bar bracket to crossbeam 22-28
Nut - stabilizer bar to link 60-80
Nut - stabilizer bar link to lower wishbone 39-55
Bolt - wishbone lower front arm to rear arm 128-172
Nut - wishbone upper fulcrum 98-132
Bolt - wishbone lower front-fulcrum 113-153
Bolt - wishbone lower rear-fulcrum 113-153
Old Jul 24, 2016 | 09:56 AM
I tightened one of the nuts on the mount that's attached to a small cross beam to body.
Went for a bumpy ride and heard nothing.
Looks like we're ok
Old Jul 24, 2016 | 11:57 AM
Ungn's Avatar
The Shock nut is usually driven home with an air gun and it hits a hard stop on the shoulder of the rod. Any looseness there is guaranteed to make noise.
Old Jul 24, 2016 | 05:16 PM
cyber3d's Avatar
Just a cautionary note for this. My replacement shocks had paint on the bolts (corrosion protection I guess) but, I failed to remove the paint before torque was applied and snapped one of the three bolts. It kept creeping and the wrench readings were off the mark.
Old Jul 24, 2016 | 08:51 PM
I put a ratchet on all the upper mount nuts and the center shock nut.
Tightened then as much as i could by hand.
Spent the day driving, and didn't hear any noise whatsoever.
gthawk1
Apr 6, 2016 01:25 AM
cbornet
Mar 30, 2016 08:35 AM
Audio/Visual Electronics
Jul 5, 2010 02:25 PM
Jan 7, 2008 09:43 AM
Jul 11, 2007 10:00 PM
