Hyd Hoses for Pump and Rams
Old Jun 8, 2011 | 05:32 PM
billm's Avatar
Default Hyd Hoses for Pump and Rams
Is there any potential problem with the remaining hoses in the truck area that feed the Hyd Cylinders/Rams that operate the top? If so, I should probably go ahead and replace them now. Comments and guidance are appreciated... __________________
Am going to order the pair (2) of hoses from Baltimore for the Conv Hyd Top fix. My sincere thanks to Gus for his efforts and documentation on this. Additionally, my sincere thanks to the Rev and the 'many others' for the the 'elect mod pressure reduction'. Hopefully, about a week I will be 'Top Down'.
Old Jun 9, 2011 | 07:24 AM
Martin's Avatar
I have two precautions that everyone with a convertable might try in order to avoid blown hoses. First... don't activate your top with the engine running. When the engine is running the voltage to the hydraulic pump is 14 volts, which provides more power to the pump motor. When the engine isn't running the voltage of course is 12 volts. This idea come from some one else on the forum. They deserve the credit, not me. The second idea....don't activate the top when the car is hot. Out in the sun the areas where the tubing runs is really hot. The hydraulic lines may me more apt the burts. So... engine not running in the shade is best.
Old Jun 9, 2011 | 07:30 AM
WhiteXKR's Avatar
Originally Posted by billm
Is there any potential problem with the remaining hoses in the truck area that feed the Hyd Cylinders/Rams that operate the top? If so, I should probably go ahead and replace them now. Comments and guidance are appreciated... .
I would say inspect them. If the outer black sheathing is soft and sticky, if you can penertrate it with your fingernail without much force, or if it is peeling, they should be replaced soon.
They do not fail as often, but they can deteriorate from heat and exposure just like the top hoses. When they fail though, it is not as dramatic ...they will not potentially spray or drip oil on you like the top hoses can.
Old Jun 9, 2011 | 10:55 AM
billm's Avatar
I have installed the 'electric pressure reduction' that came from Rev. But evidently the Hose at the Top Latch had all ready been blown by the prior Owner. So I will do Gus's 'metal braided' line repair. Top down in a week...
Old Jun 9, 2011 | 09:03 PM
Gus's Avatar
Gus
Yes you have the potential for the hoses at the rams to fail along with the seals on the rams and the seal at the latch that are known to be dislodged due to the pressure and temperatures. Should you replace them, not unless they are leaking. The hoses for the rams are as expensive as the hose for the latch. Also when we were looking at the hoses for the rams they have special fittings. We identified the cause to be the excessive pressure hence the development of the pressure relief valve. Other processes are available but I prefer the valve. That choice is yours!
dsnyder586
Dec 29, 2024 07:39 PM
Jandreu
Jun 30, 2022 03:10 PM
Wahooesprit
Dec 23, 2019 02:01 PM
Sambo21
Nov 19, 2015 03:55 PM
chatmanx
Sep 11, 2015 07:17 PM
