I may have just ruined the ECU
Old May 17, 2023 | 07:39 AM
jim_63219's Avatar
Originally Posted by barnter
It's amazing how something fairly simple can lead to a rabbit's hole of problems and that using sophisticated diagnostics can be a distraction. A few years back, I had a non-start issue with the x-type which involved a non-communicating ECM. Turned out to be corrision on the ground connections near the headlights. Live and learn. Thank goodness there are a bunch of folks on this forum who really know their stuff. Glad you got your car sorted.
Well said. In every rabbit hole journey, I always try to look at the positives of what I learn, and especially with this car, every journey brings me more familiarity with the vehicle. For instance in this case, I've learned how the ECU feeds out to all the other modules and can trigger a motley assortment of errors when failing on that one circuit. I also learned that residual charge in the ECU can give these strange 1.5v readings (they've puzzled me along the way, with my rotary switch diagnosis.)
On the other hand, I try to respect other's time and avoid ***** like this but you're right, this forum is invaluable.
Old May 18, 2023 | 05:40 AM
Pistnbroke's Avatar
The ECU takes an earth connection as a signal. Sounds like you have connected a +12v where it expected 0v and in consequence have burnt out the sensing transistor in the ECU though this may not be a discrete unit but inside a multi pin chip so not individually replaceable. as you put it on your bumpers "**** HAPPENS"
Old May 18, 2023 | 07:04 AM
baxtor's Avatar
1997 is AJ26, that ECU does not use signal to ground. That didn't change until AJ27.
As OP noted, problem is resolved.
Old May 18, 2023 | 08:11 AM
Pistnbroke's Avatar
does in my 97 diagram
Old May 18, 2023 | 08:25 AM
dibbit's Avatar
You are misreading the diagram.
The only connection to the ECU from the rotary switch is PN - you can see that comes from the fuse box 43E (which is 12v and is the WR wire the OP grounded) and goes to the ECU 04.1 04.3 PARK NEUTRAL. So when the switch is closed the ECU sees 12v and when the switch is open that input is floating (pulled down internally to ground).
All he did was blow a fuse if you read the thread.
ahmedalalousi
Jul 28, 2016 08:53 PM
rweber
Nov 18, 2010 10:48 AM
BaDAss03STR
Sep 10, 2008 09:18 AM
BaDAss03STR
Sep 10, 2008 09:17 AM
BaDAss03STR
Sep 10, 2008 02:57 AM
